586,106 active members*
3,104 visitors online*
    Nov 2008
    94
    CHNC 3 Spindle Brake
    Hello,
    Odd problem with CHNC 3. (1994/1995)
    Spindle Brake is not releasing.
    If machine is left in JOG Mode and Spindle Free button is pressed: After some time the brake will release and machine will function. (But can still stick if left idle in Auto Mode.)
    Seems like some kind of relay or electric/pneumatic switch is sticking - semi working.
    Machine has been running fine in the same place for 20 years.
    Anyone ever seen this problem before?
    Thanks!
    Dec 2013
    5717
    Re: CHNC 3 Spindle Brake
    Gummed up cylinder maybe? If an air cylinder maybe dry and needs oil?
    Jim Dawson
    Sandy, Oregon, USA
  1. CHNC Spindle Bearing replacement?
    By mike^3 in forum Hardinge Lathes
    Last Post: 08-05-2018, 11:50 PM
  2. spindle drive for CHNC-I
    By jmelson in forum Hardinge Lathes
    Last Post: 04-08-2018, 04:46 AM
  3. Spindle Won't Reach Speed after Brake On while Spindle Start
    By mflux_gamblej in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2014, 04:59 AM
  4. Replies: 0
    Last Post: 08-10-2013, 07:28 PM
  5. Need drive for CHNC spindle motor
    By rkdygert in forum Servo Motors / Drives
    Last Post: 01-27-2007, 07:03 AM
