586,105 active members*
3,297 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Building 5th Axis Machine - problems rebuilding the libraries
    Jul 2020
    Hi Tom,
    I am working on building a 5 axis machine with an AC trunnion table.
    - I have downloaded 435b and for initial testing added a Kinematics.txt file to the <>\KMotion\Data directory with the string "5AxisTableAC".
    - I can confirm that the kinematics are kicking in (and tracking well for the C rotation).
    - I need to go into the Kinematics5AxisTableAC.cpp file and change the machine Z position of the A axis rotation centerline. I think the default is something like 1.02" and mine need to more like -0.492.
    I am having a bunch of compile errors though - like can't find <new.h>.
    I have VS2017 installed with MFC and ATF support.
    Any ideas on where to start? Is there a current web page that explains this?
    Jim
    Jul 2020
    Re: Building 5th Axis Machine - problems rebuilding the libraries
    Update... I was finally able to get the Kmotion libraries to compile.
    I updated my VS installation to include all the optional components under the Desktop C++ development module. After updating, I was able to rebuild the solution.
  1. BUILDING A MACHINE AND NEED ADVICE ON 3 AXIS KIT
    By guitarded in forum Want To Buy...Need help!
    Last Post: 10-29-2019, 04:10 AM
  2. Foundation about building a five axis cnc machine ?
    By tgt1997123 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-30-2018, 01:12 PM
  3. I am building a similar machine 5 axis ,
    By jeriesfacouseh in forum Uncategorised MetalWorking Machines
    Last Post: 10-05-2015, 06:31 PM
  4. Building a 5 axis machine?
    By mkzr32 in forum DIY CNC Router Table Machines
    Last Post: 11-23-2014, 05:35 PM
  5. building a 4th axis for techno machine
    By irishii75 in forum DIY CNC Router Table Machines
    Last Post: 07-26-2007, 01:03 PM
