586,108 active members*
3,293 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Vista Video Problem
Results 1 to 16 of 16
    May 2005
    26
    Vista Video Problem
    Hi All,
    I'm running BCC 2007 on a new computer that has MS Vista on it. I have updated all my drivers to the most current.
    When I run the verify the screen redraws are bad see attachment. I read in another post this is because Vista wants to run the video through the main processor not the video card.
    Does anyone have a fix or work around for this ?
    Thanks in advance.
    George
    Jan 2006
    4396
    Quote Originally Posted by gblass1 View Post
    Hi All,
    Thanks in advance.
    George
    George,
    Yes, as far as I was told Vista wants to run the Graphics through the Processor instead of the Graphics Card.
    Call BCC Tech Support. They will walk you through the fixes.
    Cheers!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    May 2005
    26
    Toby
    Thanks for the reply. I have mentioned it to BCC tech support but they just said to update my drivers which I have already done.
    Is there someone in tech support that is knowledgeable about this problem that I should ask for ?
    Thanks again for the reply.
    George
    Jan 2006
    4396
    Toby
    George
    PM The One here on CNC Zone he will know what you need to do with Vista. He is the Man when it comes to BCC Tech Support.
    Cheers!!!!!!!
    Toby D.
    Schwarzwald
    May 2005
    26
    I just ran a little test. I loaded BC 2007 on my laptop running Windows XP and I have the same problem with the video.
    So now it seems like it may be a software problem with BC 2007.
    Thoughts ?
    George
    Aug 2003
    449
    gblass1,
    Vista actually uses the GPU more for the rendering than it uses the CPU now. The draw back or issue with Vista is the way it handles OpenGL. Instead of running OpenGL by itself to render images it uses OpenGL as a layer in Direct3D, this can create some issues.
    For resolving this issue I would have to have a little more detail. When you say the screen redraw is bad, are rotating the part in the Verify window? How is the redraw bad, are you missing surfaces?
    Regards
    May 2005
    26
    The One
    Thanks for the reply. If you look at the file I attached to my original post that is what the display looks like when I run "Verify". It has ghost images of the tool all around the tool path. This makes it hard to follow the tool when you have 6-8 tools all overlapping.
    I'm not rotating the part just letting it run the tool path.
    George
    Jul 2005
    450
    EDIT: ignore me, missed the bit about same problem under XP.
    Aug 2003
    449
    OH, you should need to just reduce the Hardware acceleration in the Graphics display. I would try making minor adjustments and checking the results, then adjust again and test until the display is correct.
    Regards
    May 2005
    26
    Unfortunately I have changed all the settings I can find and nothing seems to work.
    Since I have this same problem on my 4 year old laptop what are the chances this is a BCC software problem. My other CAD/CAM software works fine as well as all my other graphic software.
    George
    Aug 2003
    449
    It is a display issue not a software issue. The display buffer isn't being cleared properly before the next display is being input.
    Did you adjust the hardware acceleration?
    Also, so that we aren't wasting a bunch of time, what are your system specs (Processor, Graphics Processor, RAM and Version of Windows)?
    You can also PM me with your contact info and I can have someone give you a call.
    Regards
    May 2005
    26
    Here are the specs on my system
    MS Vista Home Basic
    Processor - Intel Celeron 3.33
    Memory - 2 GB
    Video - Intel 82945G Express Chipset Family
    Monitor - LG L1960TR Resolution 1280 X 1024
    Shop Phone 860-355-9790
    Cel 203-241-4759
    George Blass
    Oct 2005
    420
    gbass1,
    When I first downloaded the demo to play with I had the same problem. Just like you I had an onboard video card, it was AGP but could only allocate I think 16Mb max to the graphic card(was sharing main system memory). When I purchased the complete version I also update my card to one with 256Mb DDR and the problem went away. I think if you were to install a video card and bypass the onboard one you would be good to go.
    nlh
    May 2005
    26
    The One
    Just Put a NVIDIA 7300 GS graphics card in and everything is working great. Thanks for the help.
    George
    May 2005
    26
    Deleted
    Aug 2003
    449
    George,
    I am very happy to hear that. It is funny, you would think that all graphics drivers would have the same basic support, but nay.
    If you have any other questions let us know.
    Regards
  1. MS Vista?
    By prototect in forum Mach Software (ArtSoft software)
    Last Post: 02-24-2007, 11:31 PM
  2. Vista and Mach???
    By ifttinker in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2007, 09:58 PM
  3. Here it comes...Windows Vista...
    By fatal-exception in forum Mach Mill
    Last Post: 02-09-2007, 04:56 AM
  4. Using Mach3 with Vista
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 02-06-2007, 04:59 AM
