I am working on a part with 8 rows of hole around the axis and have no problem doing the linear array and then radial array to place the first for rows of holes at 90 degree intervals , the next set of four needs to be off set 45 degrees from the original hole .
figured it out, just needed to create a second plane 45 degrees from original
