586,051 active members*
3,776 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > pls, how to calculate the length of a spiral arch ?
    Jun 2015
    4154
    hello please, let's consider this spiral :
    ... angle 0, radius 50
    ... angle 180, radius 75
    ... angle 360, radius 100
    * thus a spiral starting from diameter 100, going to diameter 200, with a single loop
    please, is there a mathematical formula to calculate the length of this spiral, between angles 70* and 123* ?
    kindly
    Dec 2013
    5717
    Re: pls, how to calculate the length of a spiral arch ?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    thank you jim
    Nov 2012
    1267
    I tried to calculate it with integrals but gave up. Should be easy enough for a student who still has fresh calculus in his head. :wave:
    There are plenty of free cad programs on the net, why not use one of them and draw what you want,then you can interrogate the drawing to get your answer.
    Good luck.
  1. help with IR on arch
    By davismetal in forum MetalWork Discussion
    Last Post: 02-01-2012, 03:40 AM
  2. X2 arch help
    By Eritex Inc. in forum Mastercam
    Last Post: 11-24-2010, 02:23 AM
  3. how I can calculate the overpressureHi all,Could you tell me how I can calculate the
    By Lafaso870 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-08-2010, 10:38 AM
  4. HOw i calculate length of BallScrews?
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 02-25-2010, 02:36 AM
  5. calculate total path length
    By webcruiser8 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-13-2006, 09:10 PM
