586,060 active members*
4,154 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > VMC MAINTENANCE MANUAL (VM1260)
Results 1 to 15 of 15
    Jul 2020
    9
    Post VMC MAINTENANCE MANUAL (VM1260)
    Hi!
    I need a Maintenance Manual VM 1260 Doosan
    We need to replace spindle bearings.
    The spindle assembly in this machine model includes the motor in the same shaft.
    Please we need to see this assembly to procedure.
    Regards.
    Abel Bernal
    Feb 2013
    788
    Re: VMC MAINTENANCE MANUAL (VM1260)
    There is not one for a VM 1260.
    The closest I have is for an integrated AV950.
    Compare it to your parts book.
    I didn't have the time to read through and compare(Sorry, I have a training presentation due on Monday, and I'm running behind...)
    I can help decipher more, on Tuesday.
    Attached Files Attached Files
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jul 2020
    9
    Thanks Darryl....But it´s a machine similar, the assembly is different...we can´t procedure whit this...
    I hope that you can help us..
    Regards...
    Feb 2013
    788
    OK, my presentation is done.
    What can I assist with?
    This would be easier if you call me...973 803 9479
    Feb 2013
    788
    What is the serial number so I can view the parts book and see if there is a comparable manual?
    Jul 2020
    9
    Darryl:
    Thanks again for your response.
    The machine is VM1260 serial: MV0031-000091
    I need the spindle assembly manual to procedure bearing replacement
    Feb 2013
    788
    MV0031 is coming up as a VM960L
    are you certain that is the correct serial number?
    Jul 2020
    9
    Darryl:
    Jul 2020
    9
    i will send you in several minutes to your email a picture of the plate number
    Jul 2020
    9
    I´m sending you these images...
    Attached Thumbnails Attached Thumbnails IMG_20200714_110401 (1).jpg   IMG_20200715_125931 (2) husillo 12000rpm doosan mv 1260.jpg
    Jul 2020
    9
    these images is in a operator manual and picture of the machine....I hope that you can see...Regards
    Jul 2020
    9
    Sorry..serial is MV0032-000091
    Jul 2020
    9
    I know that this machine was sold in Korea....but it was moved to Mexico ....the owner is Korean company....
    Feb 2013
    788
    MV0032
    hang on...
    Feb 2013
    788
    I could not find a Maintenance manual that matched close enough. This is the best I could do.
    I hope it helps to clarify. Call me if you wish to discuss. 973 803 9479
  1. Colchester 3000l maintenance manual, parts manual
    By jaqn in forum Colchester Tornado lathes
    Last Post: 11-17-2017, 02:41 PM
  2. Replies: 5
    Last Post: 02-16-2016, 12:42 AM
  3. Replies: 0
    Last Post: 05-14-2015, 11:12 AM
  4. Replies: 0
    Last Post: 06-17-2010, 12:59 PM
  5. Maintenance manual
    By Vince4 in forum Fanuc
    Last Post: 02-19-2007, 12:35 PM
