586,060 active members*
4,226 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > I need to reduce the OD of a stainless steel washer.
    Nov 2006
    4
    Hello guys, i need to reduce the OD of a stainless steel spacer/washer. The approx dimensions are 2” od, and 2mm thick .
    i was thinking of a rotary axis lathe with a stepper motor. Can this moto be wired to run at a continuous higher speed only?
    Nov 2006
    4
    Re: I need to reduce the OD of a stainless steel washer.
    Nov 2006
    4
    Dec 2013
    5717
    What equipment do you have available? That is really a good job for a lathe, just attach the washer to a stub arbor.
    Jim Dawson
    Sandy, Oregon, USA
