586,533 active members*
2,798 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 1/16 ball end mill w/ 1/8 shaft Tool
Results 1 to 7 of 7
    Feb 2009
    214
    How can I enter this in my Tool Library?
    I have tried to modify holders and arbors to accomplish this with no luck.
    my problem is I have a small deep cavity that has detail in the bottom of the cavity and with out the 1/8 shaft info in the cutting operation my tool rubs on the side of the cavity and burns the belt off.
    I can set a boundary for 1/8' so it does not rub but I would like to have the info in the tool so it will at least cut to the depth without rubbing.
    David L. Aery
    www.hooksolutions.com
    Jun 2008
    1838
    Re: 1/16 ball end mill w/ 1/8 shaft Tool
    Hi David
    Have you tried creating a Form Tool the size and shape you need ?? You just draw half of the shape and then you can create a new tool in your Tool Library and "Assign Geometry" and the tool will be created to your drawn shape, see images below
    The above is just a rough example to give you an idea of the steps required, hope it helps you some
    Regards
    Rob
    Feb 2009
    214
    thanks, that helps a lot.
    but my tool doesn't show a ball nose and yours does. it also does not simulate the ball nose. what am I doing wrong?
    David L. Aery
    Feb 2009
    214
    I chekced my geometry and did have a line not connecting now I think it is working.
    Thanks!
    David L. Aery
    Feb 2009
    214
    whenever run a simulation I get an error
    Attached Thumbnails Attached Thumbnails Screenshot 2020-07-20 09.45.18.jpg   Screenshot 2020-07-20 10.21.19.jpg
    David L. Aery
    Jun 2008
    1838
    Hi David
    I don`t see the Form tool in your Tool Selection image ??
    What version of BobCAD are you using ??
    Regards
    Rob
    Feb 2009
    214
    I have ver 29
    my "add" tool looks like yours in the above post, not sure what you mean by "Form tool"
    I openned a new file and drew my tool and added to the tools but when I would open my machining file and try to add the tool to an operation it didn't work as expected.
    I may have been in a hurry
    I will work with it some more.
    thanks,
    David L. Aery
  1. Shaft and ball screw nut - mounting method
    By sn4il in forum MetalWork Discussion
    Last Post: 02-26-2019, 07:17 PM
  2. Flexible coupling for 4.5 mm ball screw shaft
    By Avitus in forum Linear and Rotary Motion
    Last Post: 07-22-2016, 07:40 PM
  3. How do I program turning a ball on the end of a shaft?
    By cdntoolmaker in forum G-Code Programing
    Last Post: 01-26-2013, 01:38 AM
  4. Replies: 7
    Last Post: 09-26-2011, 10:53 PM
  5. Ball end on shaft?
    By Fastest1 in forum BobCad-Cam
    Last Post: 11-19-2010, 06:07 AM
