586,080 active members*
3,667 visitors online*
Results 1 to 13 of 13
    Jul 2004
    42
    DMM servo set up
    I have a older set of DMM 60EM-DHT-36 400 watt servo motors and Dyn2-h drives. What programs do I need to download to get the system running. I have a laptop with Window 10 and only has usb ports. I would like to use these on a PM-25 mill I just ordered.
    Dec 2013
    5717
    Re: DMM servo set up
    You will most likely need the USB comm cable from DMM https://store.dmm-tech.com/products/...e-ca-mtusb-fr1
    And the software DMM | Technology Solutions | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Check with DMM for compatibility with your older Dyn2 drive, their tech support is very responsive.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2004
    42
    I dont see the older soft ware lisetd. I downloaded the new software but the only cable I have is the short one with yellow tape on it in my picture. Just no way to hook up. I will get with DMM on Monday and ask. Thanks Jim
    Joe
    15362
    Quote Originally Posted by wantacnc View Post
    They are some of there oldest Drives and motors I think they have made it so the new software is still compatible with the older drives I have the old software though, I will have to see if I can some how copy it from an old computer to a USB drive, they will have the software if you contact them they will give you a link to down load it from
    I have some of the same that have been running for years I have done some modes with the cables though as those connectors or not very reliable for the Encoder cable
    You will need to run those motors with a 2:1 Gearing for that mill
    The cable you have you would need to have an adaptor to suit what ever your computer has to use for a comport
    Mactec54
    Jul 2004
    42
    I did try using a USB cable to the port on the break out board but mt lap top wouldnt find the port Using the newer software.
    So with using 1605 ball screws I would need to go 2:1 gearing correct Mactec, I guess the servos run to fast?
    Joe
    15362
    Joe
    No the USB port on the Breakout Board is for a optional 5v Power supply only
    No they would not run to fast the Gearing is required so you have enough power to move your X and Y axes
    Mactec54
    Dec 2013
    5717
    Joe
    The USB cable supplied by DMM connects between the laptop and the drive. It is a USB serial port adapter interface.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2004
    42
    Does anyone have a DYN Servo Drive USB Tuning Cable CA-MTUSB-FR1 they want to sell? Shows to have at DMM in canada but anything shipping across the border can take months. Beg borrow so I can get my stuff running, Let me know.
    Joe in St. Louis MO.
    Dec 2013
    5717
    I normally get stuff from them in 2 or 3 days. With ground shipping.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2013
    5717
    I see your dilemma. No, I haven't purchased anything from DMM in the last several months.
    Since you already have a serial comm cable, maybe just a USB serial port adapter from Amazon would work. https://www.amazon.com/Sabrent-Conve...s%2C223&sr=8-3
    Jim Dawson
    Sandy, Oregon, USA
    I've got a couple of these old DYN2s on my Bridgeport X and Y axes. As you've suggested, the adaptor shown in the first photo is for a std RS232 port, which is still supported by the current software. You should be able to get an RS232 to USB adaptor from ebay or Amazon for peanuts.
    I have a 2005 ballscrew and 2.5:1 reduction, so on the face of it, 3000rpm would give 100mm/second ie 6m/min, if the ballscrews were happy rotating at 1200rpm.
    Jul 2004
    42
    I will order https://www.ebay.com/itm/DTECH-DB9-S...EAAOSwtfhYnkXx
    This cable will mate to the DMM male pins on the cable I have, Im sure ill be back for more help on this when I get the cable. Thank you very much guys, This mill has been a dream of mine for years and hope I finally get it all sorted out.
    Joe In St Louis Mo
  1. Servo Drives EG&G Torque Systems servo drive model ACU3015-100D
    By CATCH22 in forum Servo Motors / Drives
    Last Post: 01-23-2020, 11:02 PM
  2. Servo Dynamics servo drives not working on a Kondia/Clausing knee mill.
    By LoweryRacing in forum Servo Motors / Drives
    Last Post: 12-27-2019, 07:37 PM
  3. Replies: 44
    Last Post: 06-21-2019, 10:35 PM
  4. Replies: 0
    Last Post: 02-07-2014, 01:29 AM
