586,108 active members*
3,084 visitors online*
    Jul 2020
    4
    Post CYCLE84 USING ANGLE HEAD 90 °
    Hello everybody!
    I,m new using this plataform to be in touch with colleagues about CNC programing and I hope does anybody can help me.
    I will machining one drill and and thread (M8 X 1.25) using an angle head 90° with a tap, the hole is in G19 reference plane XY, thread axis is paralel to X axis of the machine, is the first time that I need to machining a hole that is not perpendicular to Z axis.
    My doubt is:
    If I program G19 before the CYCLE84 then all the parameters for the cycle will be reference to that plane (G19 YZ)? for example for the parameter "DP" final Depth the machine will move in X axis because I selected G19? works like this? if not how I have to program it?
    Jul 2010
    118
    Re: CYCLE84 USING ANGLE HEAD 90 °
    hi,
    welcome
    you can start by informing us about the machine make & model + cnc control type & model.
    el's we have no clue
    Jul 2020
    4
    Post Re: CYCLE84 USING ANGLE HEAD 90 °
    Thank you norbert the machine is SW BA W06 -22 and CNC control is SIEMENS 840D Solution line
  1. Right Angle Head on a BTC
    By chipmakes in forum Bridgeport / Hardinge Mills
    Last Post: 02-18-2018, 07:11 AM
  2. RIGHT ANGLE HEAD
    By MACHINEFREAK in forum GibbsCAM
    Last Post: 09-14-2015, 04:00 AM
  3. Cycle84
    By shtelica in forum OneCNC
    Last Post: 02-14-2013, 06:31 AM
  4. Right Angle Head
    By camtd in forum UG NX
    Last Post: 05-15-2012, 06:14 PM
  5. right Angle Head help
    By inkydo69 in forum Mastercam
    Last Post: 04-08-2009, 03:58 PM
