586,072 active members*
4,476 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Z wave axis will not fully retract in time before moving
    So out of the blue my z axis is not retracting fast enough to clear the cut before it goes to the next cut and its cutting my projects up. Ive cut this piece 20 times and all the sudden it starting doing this. Ive checked my steps. Ive checked my machine axis and my work axis. Ive checked my safe Z in vcarve. I am racking my brain trying to figure it out!
    Attached Thumbnails Attached Thumbnails IMG_0364.jpg   IMG_0367.jpg   IMG_0368.jpg
    Apr 2004
    5737
    Re: Z wave axis will not fully retract in time before moving
    See if you're losing steps in Z by commanding a few moves and then a return to zero. Each move should complete before the next one is started, but if the Z axis isn't retracting to its clearance height that would account for it.
    Andrew Werby
    Website
  1. LAser cutting machine makes a wave in a corner at the time of cutting
    By angeldp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2017, 03:51 PM
  2. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  3. Replies: 4
    Last Post: 10-12-2013, 05:46 AM
  4. My CNC router gets out of alignment when moving in X and Y at the same time
    By DominiqueRivest in forum Mach Software (ArtSoft software)
    Last Post: 08-24-2013, 11:44 AM
  5. Y-Axis Mexican Hat Wave?
    By SDesigns in forum Syil Products
    Last Post: 07-09-2009, 08:21 PM
