586,119 active members*
3,477 visitors online*
    May 2009
    32
    4th axis question
    I installed a Koma 4th on a mill with an Oi-F controller. The rotary will move and go to the commanded position just fine. The position page shows the position for the rotary. My problem is that in the work offset page the 4th axis is not visible. I can't set any offsets for the 4th axis. Any ideas?
    Re: 4th axis question
    I only see it being avaiable in the "T" control which is the lathe type.
    Jul 2017
    50
    Probably prm 3134
  1. 4th axis question
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 09-04-2017, 11:55 AM
  2. Y-Axis / Z-Axis Bearing Setup Question
    By KittyPants in forum DIY CNC Router Table Machines
    Last Post: 08-22-2013, 10:45 AM
  3. Rookie Question...3 axis vs 4 axis controller
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:04 AM
  4. question about 4th. axis
    By 69ss396 in forum Haas Mills
    Last Post: 07-01-2009, 04:13 PM
  5. 5 axis question
    By turmite in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2005, 11:34 PM
