586,069 active members*
3,425 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Lb3000ex 2 IGF C-axis Programming
Results 1 to 6 of 6
    Jul 2020
    Hi guys. Im having some trouble getting my machine to do what I want. Im sure its simple but I cant figure it out so I seek some help.
    OSP-300l Control
    So Im trying to mill in a water jacket using my c-axis with a double lead. I get shape underdetermined when I try and do it.
    If anyone would be able to help me Id greatly appreciate it. Honestly prob easiest via phone or text so I can take pictures to explain everything and let you get a vision of what Im trying to do.
    Please PM me if your able to help and we can share contact info.
    Jun 2015
    4154
    Re: Okuma Lb3000ex 2 IGF C-axis Programming
    hy mike there are a few code types when using c axis : [ G01 or G101 or G102 or G103 ] + [ X or C or XC ] + [ nothing or Z ], and some others
    igf is not able to generate all of them
    i need to know what kind of toolpath you need; it may be able to generate it using igf, but, if it's simple, it may be faster to write the g-code
    kindly
    ps : maybe share a photo with your actual shape in igf ? or coordinates ...
    Jul 2020
    here is the print of what im trying to do.
    All I want is my c to rotate at the pitch. flip it 180 and repeat. Just not sure how to make it do it.
    Attached Thumbnails Attached Thumbnails IMG_2415.jpg   IMG_2413.jpg   IMG_2406.jpg
    Jun 2015
    4154
    hy mike if you would use an endmill with dia 0.378, then it would be required to cut a helix with a number of loops = (3.8898-0.5512)/0.5315=6.28146...= 2pi
    let's round that up, at 7 : this means a clearance of 7-2pi; pls be aware that this clearance is relative to the right side of dimension 3.8898, and this is not your part face ... thus, if you have Z0 on the right, then, before cutting 7 loops, you should shift your Z0
    Code:
        V1 = rpm
        V2 = feed_in_g95
        V3 = target_diameter
        V4 = turret post
        G00 X_up Z_rigth
        T+V4*101
        M110
        SB=V1 M13 ( M08 )
        VZSHZ = - [ 3.9370 - 3.8898 ] + [ 7 - 2 * VPAI ]
        G00 X=V3 Z0 C0 ( M15 or M16 )
        CALL OSUB Q=7*2
            X_above_part G90 F
        M12
        M109
        G00 X_up Z_rigth T+V4*100 VZSHZ = 0
    OSUB
        G01 Z-0.5315/2 C180 G91 G95 F = SQRT ( ( (  360 * 0.5315 / 2 ) ^ 2 + ( 500 * 180 ) ^ 2 ) / ( ( 360 * 0.5315 / 2 ) ^ 2 + ( VSIOX * 180 * VPAI ) ^ 2 ) ) * V2
    RTS
    * at least for this operation, g-code can be written faster than messing with the igf
    if your tool dia < 0.378, then is needed to compute each pass ... or, it would be possible to rough towards same Z end, and finish like showen in attached image
    what kind of tool do you use? perhaps a custom tool is affordable ...
    c & z axis should work syncronuous
    by the way, is possible to rough that by using a threading insert, but, after that, is required to "merge" M19 and C origins
    kindly
    Jul 2020
    thank you sir! I will give this a try. I do have a custom ground tool to do it with. I appreciate your time.
    Jun 2015
    4154
    ok i have edited the code, so instead of cutting 14*180degrees, it now cuts 7*360degrees; this should deliver a smoother movement
    i don't know exactly the dimensions of your part, but i suggest you rough with a tool dia < custom tool dia, then pre-finish and finish with your custom tool
    something like this :
    ... cut at X_start - X_depth_rough * 0, with tool_1
    ... cut at X_start - X_depth_rough * 1, with tool_1
    ... cut at X_start - X_depth_rough * 2, with tool_1
    ... etc
    ... cut at X_start - X_depth_rough * n, with tool_1
    ... cut at X_end + X_depth_finish * 2, with custom tool
    ... cut at X_end + X_depth_finish * 1, with custom tool
    ... cut at X_end + X_depth_finish * 0, with custom tool
    * thus just edit V3 inside that program
    this should put less stress on the custom tool, thus keeping it's wear to a minimum necessary
    tool_1_dia should be < custom_tool_dia ... also, tool_1 may be a bit blunted, it does not matter, as long as it leaves enough material, so your final tool to deliver a smooth surface
    at the end, would be ok to run a chamfer tool, in order to debur your edges ... this requires a code that cuts on a cilinder surface; but maybe you just find something arround there / kindly
    Code:
        tool Z offset = tool center, not tool ege
        run it easy at 1st, step-by-step, be aware of where it
    is going before pushing cycle start; approach is directly
    at cut diameter, there is no feeding among X-
       carefull with Z clearance, because is a little big than
    usual, and maybe it will colide with the tailstock ... in such a
    case, pls let me now if you need a modified clearance; don't modify it
    directly inside the program, because it corelates with the number of
    loops, and, instead of 7, there will be a decimal number, that has to
    be calculated
        V1 = tool rpm
        V2 = feed_g95 for the helix
        V5 = feed_g95 for final retreat among X
        V3 = target diameter
        V4 = turret post
        G00 X_up Z_rigth
        T+V4*101
        M110
        SB=V1 M13 ( M08 )
        G00 X=V3 Z0 C0 M15/M16 ( choose how the helix wraps arround )
        CALL OSUB Q7
            X_above_part G90 F=V5 ( don't rush this movement, also don't use G00, because tool may cut during it's way out; tool retreat/disengage is different when C axis is used )
        M12
        M109
    OSUB
        G01 Z-0.5315 C359.999 G91 G95 F=SQRT((360*0.5315*360*0.5315+500*360*500*360)/(360*0.5315*360*0.5315+V3*360*VPAI*V3*360*VPAI))*V2
    RTS
