587,011 active members*
3,875 visitors online*
Thread: Pull stud
    Apr 2008
    82
    Pull stud
    I have read that fadal bt 40 pull studs are the same as mazak?
    Could someone confirm this.
    I can get mazak pull studs here in Australia but not fadal and to get them shipped from US costs more in shipping than the pullstuds.
    Plus our dollar sucks against the US Dollar at the moment.
    Cheers.
    Jun 2007
    61
    Re: Pull stud
    Can't say for sure on the BT40 but the CAT40 pull studs are the same as Mazak.
    Ed.
    Jan 2015
    417
    Re: Pull stud
    There is usually a Drawing of both the Cat and the BT pull-studs on the side of the back control box above the Power disconnect.
  1. Max Pull stud Runout??
    By mmurray70 in forum Fadal
    Last Post: 07-20-2016, 02:08 AM
  2. Pull stud grippers - how to make jaw type stud gripper?
    By Azalin in forum Vertical Mill, Lathe Project Log
    Last Post: 12-29-2015, 12:56 PM
  3. Pull-Stud identification
    By andypugh in forum Uncategorised MetalWorking Machines
    Last Post: 02-14-2013, 01:19 PM
  4. Pull stud?
    By Ph2011 in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2011, 01:07 AM
  5. need help with pull stud
    By pper in forum Tree
    Last Post: 05-23-2011, 05:02 PM
