586,060 active members*
4,592 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > '92 VF-2 AC Servo Equivalent
    Apr 2010
    20
    I cant find the specs for the original Brushed DC motors nor do I have all the elements required to create an accurate motion profile. I have come across second hand info that states the motors are 3000 oz/in (21 Nm) which I would assume is peak output and 3000 rpm. Can someone please offer continuous/peak torque requirements and rpm or a known motor spec or part number of an AC brushless version for this application? Also what is the actual resolution of the original system or later models? I see the encoders are 2000 cpr but with a 6 mm lead screw this equates to .000118". The control dial allows .0001" increments so it must be better than the .000118". Do the A/B channels mean 2000 lines are actually 4000 signals for 1 rotation? Thanks
    myspace.com/1metalmorphose
    Dec 2013
    5717
    Re: '92 VF-2 AC Servo Equivalent
    These guys might be worth a look DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    I have been very happy with their products.
    Yes, 2000 lines should equate to 4000 pulses/rev.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2010
    20
    Thanks for the link Jim. They seem very reasonable cost wise. That's a plus since this machine has been retired to hobby use
  1. Servo equivalent to Stepper Help
    By Cartierusm in forum Servo Motors / Drives
    Last Post: 12-27-2017, 10:43 PM
  2. Milling equivalent of G71
    By scrapper400 in forum G-Code Programing
    Last Post: 12-03-2008, 06:02 PM
  3. Replies: 8
    Last Post: 06-24-2008, 06:20 PM
  4. Equivalent servo system of step motor
    By bunalmis in forum Servo Motors / Drives
    Last Post: 11-23-2006, 12:33 AM
  5. G71,73,70 equivalent's for Milling ?
    By iMisspell in forum G-Code Programing
    Last Post: 08-08-2006, 06:45 AM
