586,119 active members*
3,493 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Question what determines the resolution of a Glass linear scales ?
Results 1 to 9 of 9
    Aug 2004
    210
    Hello there
    I am trying to figure out what determines the resolution of a Glass linear scales ?
    Is it the glass, the read head or both ???
    Is there anyway to tell by eye ??
    Dec 2013
    5717
    re: Question what determines the resolution of a Glass linear scales ?
    Both. The read head has electronics the interoplates the pulses from the lines on the glass. There is no way to tell by eye. The easiest way is to connect the scale to your machine encoder input and see how many pulses it generates in 1 inch or 25mm of movement.
    Jim Dawson
    Sandy, Oregon, USA
    24221
    It is quite a unique process, the typical linear scale or rotary incremental encoder, which uses a similar method by using a read head that uses photo electric sensor, the moving head carries a small section of glass scale with the same resolution as the main scale, but with a slight tilted angle, this creates something called the Moiré effect, which essentially creates a shutter which essentially magnifies the minute resolution/increment of the scale in order for the read head to register the change in pattern.
    Otherwise the typical resolution of a scale such as say, a 2µm scale, would not be able to be read by a normal photo sensor.
    So the bottom line, as Jim said, it would be impossible to tell by eye.!
    Al.
    Albert E.
    Sep 2018
    15
    Re: Question what determines the resolution of a Glass linear scales ?
    Al.
    Is this the same with magnetic scales? ...Are there little tick marks that get picked up magnetically somehow?
    Dec 2013
    5717
    Quote Originally Posted by rallyx99 View Post
    Yes, that is exactly how they work. The magnetic lines on the magnetic strip are normally spaced at 2mm, the two sensors in the read head somehow sort it all out, and output a pulse train with resolutions as small as 1 micron (or smaller on the high end units).
    Jim Dawson
    Sandy, Oregon, USA
    24221
    In the optical version. the 'trick' is the Moiré effect, the lines that are spaced down to 2µm is impossible for the typical photo-cel to distinguish between such a fine grating, the small piece of grating that is carried by the head is tilted slightly to create a much larger shutter effect.
    In some cases you can see this under strong light in a rotory encoder by turning it slowly, the 'shutter' created is about the same width as the grating height, thus enabling what would be an impossible task for a read head to distinguish such a fine resolution.
    Incidentally, the 'shutter' rotates at right angles to the direction of head motion.
    It is quite neat to see in person.
    The quadrature, 90 deg, shifted pulses can be read on all four edges, thus magnifying the quadrature pulses x 4.
    In the magnetic head, often a different system is used using the co-tangent difference between the two quadrature sine wave pulses.
    Al.
    Albert E.
    Sep 2018
    15
    That’s pretty interesting! So based on that, it seems like it should be possible to make the read device miss lines by moving it really fast in relation to the scales. Is this correct?
    Dec 2013
    5717
    Depends on what you mean by ''really fast''. A 1 micron resolution scale will read reliably at about 4M/sec, with the standard read head, and as fast as 37M/sec with an optional read head. 4M/sec (~17 ft/sec, ~12,000 IPM) is much faster than I would ever run a normal machine tool.
    Jim Dawson
    Sandy, Oregon, USA
    24221
    Probabally comes down to the frequency response of the read head components, the rate of response of the controller, and the form of transmission.
    Al.
    Albert E.
  1. Cleaning Linear Glass Scales
    By warrenb in forum Maintenance DIY Discussion
    Last Post: 05-02-2019, 07:59 PM
  2. Working out the required length of linear glass scales
    By hotponyshoes in forum MetalWork Discussion
    Last Post: 06-24-2008, 02:03 PM
  3. Connectors on glass linear scales - interchangable?
    Last Post: 05-17-2007, 07:56 AM
  4. Sorce of used linear glass scales / encoders
    By hotponyshoes in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2007, 07:17 PM
  5. good source for cheap glass scales/linear encoders?
    By mbwittig in forum Bridgeport / Hardinge Mills
    Last Post: 10-25-2006, 05:58 AM
