586,036 active members*
3,497 visitors online*
    Nov 2015
    8
    CRP4824 X axis backlash issue
    Greetings,
    I am wrapping up the construction of a CRP4824 kit build and I've noticed I had a LOT of backlash on my X axis. It turns out that one of the bolts holding the Nema 23 motor onto the Rack and Pinion drive is hitting the carriage and preventing the gear from settling nicely in the bar with the gear teeth milled into it. I double checked the instructions and it's assembled correctly. The Y1 and Y2 axis don't have this problem as the milled teeth are further away but the X axis does. Aside from grinding a relief in the carriage, which I do not want to do. Is their a clever way to fix this? I tried swapping sides and moving the NEMA 23 motor around but I had no luck and either side I choose, it's still there.
    Mar 2017
    250
    Re: CRP4824 X axis backlash issue
    I'm wondering if that's a one off issue or if others have the same.
    When building my crp4896pro, my gantry plates were too big to flush mount my bearing rails. I had to machine the fronts to seat them properly. It was the only thing I had to do that on. But since then, a couple years ago, I've never seen that come across on the forums. You might have a similar thing. A qc issue possibly?
    Sent from my SM-N960U using Tapatalk
    Sep 2005
    1740
    Can you replace that bolt with a allen head bolt of some type and have you contacted Avid / CNC Router parts?
  1. Strange Z backlash issue
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2013, 11:50 PM
  2. Mach3 Backlash Issue
    By strohkirchw in forum Taig Mills / Lathes
    Last Post: 12-08-2010, 09:35 PM
  3. X3 Z Axis Backlash Issue
    By dneisler in forum Benchtop Machines
    Last Post: 01-04-2009, 03:50 PM
  4. Leadscrew backlash nut issue.
    By jaydee116 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2004, 01:57 AM
