586,113 active members*
3,429 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Mar 2015
    Quote Originally Posted by patrick31 View Post
    Thought I would share my limit switch noise solution. I searched here looking for answers a couple years ago when my PM25 CNC conversion kept getting false triggers on the limit switches. I wired in some resistors which helped, but never totally fixed it. I tried shielded wires too but that didn't work.
    I kept getting "Limit Switch Triggered" in Mach 3 while cutting, which would freeze the machine. I have a 48V system two large Nema 23's and a Nema 34, all running at 5A's.
    Anyways, I researched it and decided to make a better solution.
    My limit switch filter board puts a load across the limit switches to reduce voltage spikes, an RC circuit to filter that signal, then a Schmitt trigger to remove jitter and add hysteresis, a level shifter to convert the signal to 5V, and current limiting resistors to protect the output wires from short circuits.
    It's been on the machine for the last couple months, and has finally fixed my noise problem!
    Pics of the final board and a screenshot of the signals!
    Patrick,
    Is it possible to have schematics or gerber file to reproduce your board?
  2. #22
    Nov 2007
    361
    eBay Item #
    Did you ever find his board or get the ebay number ??
  3. #23
    15362
    Re: Limit Switch Noise Fixed!
    Quote Originally Posted by Michael82 View Post
    eBay 193599398725
    Mactec54
Page 2 of 2 12
  1. Limit switch noise: Optocoupler, 12v, 24v?
    By Biggs427 in forum CNC Machine Related Electronics
    Last Post: 09-06-2023, 07:38 AM
  2. Triple Play Solid State Limit Switch Noise Filter
    By mill808 in forum CNC Machine Related Electronics
    Last Post: 04-19-2017, 11:07 PM
  3. Electric noise - home/limit switch
    By feragto in forum DIY CNC Router Table Machines
    Last Post: 11-21-2010, 06:33 PM
  4. Need help with noise on limit switch cables. Elco or AC cap?
    By riva in forum CNC Machine Related Electronics
    Last Post: 11-14-2008, 12:04 AM
