586,275 active members*
3,206 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Need some rule of thumb numbers for machining 1018 steel
Results 1 to 6 of 6
    May 2013
    169
    Hello,
    Up to this point all of my machining has been on Alum, but I'm starting to venture into 1018 steel and just need some advise on some starting recipes.
    I'm running a Haas super mini mill with 15HP spindle.
    if you could give me your suggestions for 1/4" 3 flute end mill that would be great.
    Here are the numbers I was going to use... ( so please give me your suggested changes )
    I will be mainly cleaning out some 1/2" pockets
    SFM: 250
    RPM: 3820
    Feed/Tooth: .001
    Feed Rate: 11.46
    Step Over: .05"
    Depth of cut: .05"
    Thank You,
    Kent
    Dec 2013
    5717
    Re: Need some rule of thumb numbers for machining 1018 steel
    Those numbers seem a bit conservative, assuming a carbide end mill. I would take a look at the endmill manufacturer spec sheet and follow those recommendations. Your machine is plenty stiff to handle a lot more load, and for a 1/2'' pocket a 3/8'' endmill might be a better choice. Depth of cut could be at least 0.25, 0.050 stepover seems OK, depending on the tool path configuration.
    Jim Dawson
    Sandy, Oregon, USA
    May 2013
    169
    Thanks much for the info Jim...
    I have to admit that I tend to baby my machine by going conservative. I am still use to running bench top machines.... so I need a good nudge once in a while to get more aggressive on the Haas.
    One follow question... when you said a Depth of cut of .25 which end mill size where you referencing? ( 1/4" or the 3/8" ) ?
    Thanks again...
    Kent
    Dec 2013
    5717
    Normally a DOC of 1D is more than acceptable. So for a 3/8'' endmill a DOC of 0.375 is fine. I'm not recommending machining like in the following video, but it does show what is possible under perfect conditions. A bit more machine than your super mini, but you'll get the idea. We routinely machine 1D DOC in 304SS on our Haas TM-2p
    Jim Dawson
    Sandy, Oregon, USA
    May 2013
    169
    I follow Titan.... but have not seen this video... That is GREAT! ( I would have to wear diapers running that aggressive! ha..ha.. )
    I finished up one of the mold plates and no broken bits... and I'm happy with the finish..
    Thanks again Jim...
    Kent
Name:	Cut Example.jpg
    You should check out the Little machine shop web site they have a simple to use calculator for speeds and feeds there and it is very good. I have recently started cutting P20 toolsteel and its always worked out for me.
    Good luck.
  1. 1018 steel machining
    By surfit in forum MetalWork Discussion
    Last Post: 01-12-2016, 05:28 PM
  2. Helix milling rule of thumb for tools
    By Cydon in forum Milling
    Last Post: 11-14-2011, 06:32 PM
  3. Laser power vs. cutting depth data/rule of thumb
    By adamchapman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2010, 05:55 PM
  4. Stepper Motor Size Rule of Thumb
    By jallenmorris in forum DIY CNC Router Table Machines
    Last Post: 09-09-2009, 01:08 AM
  5. machining 1018 steel
    By busted bit in forum MetalWork Discussion
    Last Post: 06-26-2009, 08:19 PM
