586,713 active members*
2,950 visitors online*
IndustryArena Forum > CAM Software > Alphacam > 2015 R2 - Can't save NC-Code
    After upgrading from 2014 to 2015, I cannot save any files. I get an error that says "WARNING: NC-CODE NOT SAVED!". Any recommendations?
    Apr 2010
    89
    Re: 2015 R2 - Can't save NC-Code
    Does it display a message "some toolpaths are hidden. NC Code will NOT be output" before the "WARNING: NC-CODE NOT SAVED" message. If it does then you need to add the following lines to your Post Processor.
    $545 Allow output of visible operations only (1 = Yes, 0 = No).
    Hi Frank,
    There are no error messages prior to the message. When I open the *.cnc afterwards there are no lines of code. It looks more like a summary of what's supposed to happen.
    Below is what I see on the .cnc file:
    Operation List POST: AlphaCAM Schmoll Squares & Circles (Anaren)_V6
    OP 1 FINISH PASS TOOL 1 050 BIT
    EFFECTIVE DIAMETER 0.05
    Feed Distance: 29.7 Time for OP 1: 0m 29s
    Total Feed Distance ......................... 29.7
    Tool Change Time .......................... 0m 00s
    Total Time ................................ 0m 29s
    Material: MDF
    Use Extraction
    START
    '(L350200A)
    Apr 2010
    89
    Can you Post your Drawing (.ard) file and Post Processor so we can see if there are any anomalies in the Post that are causing this issue.
    Just change the extension on the .ard file to something this site accepts.
    Also try different Post Processors to see if they generate code
  1. Cant export or save as G-code
    By Jiminator in forum Uncategorised CAM Discussion
    Last Post: 09-09-2016, 05:36 PM
  2. Replies: 0
    Last Post: 06-26-2013, 08:17 PM
  3. How to save G code?
    By MitchB in forum MadCAM
    Last Post: 07-20-2012, 07:20 PM
  4. save g code as
    By js412000 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-16-2010, 02:33 PM
  5. Save G-Code
    By Rally in forum HURCO
    Last Post: 08-19-2009, 06:04 AM
