586,094 active members*
3,889 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas High speed machining won't turn back on, after turning it off
    Apr 2017
    8
    Question Haas High speed machining won't turn back on, after turning it off
    I have a problem with my OM2a
    I (temporarily) disabled high speed machining.
    Because I wanted to see what the difference was in machining time.
    After I did my test, (and o boy what a difference.) I wanted to turn it back on.
    However I am unable to do this, when I try to change the parameter back from 0 to 1, I get a beep, but nothing happens.
    Other parameters a can change with no problem only high speed machining won’t turn back on.
    Hopefully it’s something stupid and it’s an easy fix.
    I have an OM2a Office Mill from 2007
    Re: Haas High speed machining won't turn back on, after turning it off
    I've never known of anyone ever turning it off but if it won't let you turn it back on then , you may need to re-enter your code or it's possible you'll need to get a new code from haas
    I agree , the difference of having hsm vs not is a night and day difference
  1. can i front/back turn in one Turning project?
    By cryptopsy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-23-2018, 02:47 PM
  2. Haas high speed machining hsm
    By allenp in forum Haas Mills
    Last Post: 06-10-2016, 09:54 PM
  3. HAAS VF2-SS High speed machining 15-5.
    By hairball in forum Videos
    Last Post: 09-18-2013, 07:44 PM
  4. Paying $2300 to turn on high-speed machining?
    By MarkSerbu in forum Haas Mills
    Last Post: 05-22-2011, 03:49 AM
  5. turned high speed off and can't turn it back on.
    By mishikwest in forum Haas Mills
    Last Post: 03-31-2010, 05:52 PM
