586,105 active members*
3,221 visitors online*
    Aug 2020
    6
    Questions about MKS-V, WHB04B-6
    Hey,
    Years ago I buy Chineze 6040z cnc machine, 4 axis. After about half of year I meet first problem - Z axis stepper lose steps randomly... And it makes Z axis fall down 2 mm every lose steps cycle... So I disassembled original control box, buy new box, hybrid stepper motors, 36 VDC 15 A power supply and connect everything back with flexible, shielded cables and etc... Well, this makes big improvement. Everything now is OK, but I am tired work with Mach3, so I am looking to LinuxCNC. I am not new with linux - spend more than 2 years with it in my College, so I think it will be better for me.
    Now I have Chineze MKS-V-V0.4 PCB, that runs everything from my PC via USB cable. Also I use WHB04B-6 handwheel.
    Did someone allready tried use this PCB with LinuxCNC ? I see, that there are some posts about WHB handwheel, but about MKS-V series PCB no. Is it avalible or not ?
    Thanks for answers !
    Aug 2020
    6
    Re: Questions about MKS-V, WHB04B-6
    BTW I am using that board with 4 axis. If MKS-V-V0.4 is not avalible with LinuxCNC, which PCB with ethernet or USB, even LPT port You preffer and why ?
    Jan 2007
    146
    Quote Originally Posted by morphxp View Post
    I think Linux CNC doesn't support USB. It does support Ethernet and parallel port, so I would stick with those options
  1. WHB04B-4 and UCCNC???
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 04-10-2023, 07:47 PM
  2. XHC WHB04B-4 with USB-RECEIVER
    By craig00747 in forum UCCNC Control Software
    Last Post: 07-13-2020, 06:06 PM
  3. Replies: 3
    Last Post: 06-21-2020, 05:12 AM
  4. XHC WHB04B-4 pendant
    By CATCH22 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-02-2020, 11:09 AM
  5. XHC WHB04B-4 Drivers
    By jimskeet in forum Mach Software (ArtSoft software)
    Last Post: 03-25-2017, 04:59 PM
