586,682 active members*
2,547 visitors online*
    Mar 2019
    94
    Fanuc 21m mm to in not accurate
    Miyano mill
    Changed over to inches par 1001 and 0000 but the resolution on the DRO showes twice what I’m actually moving. If this was the cross feed on my lathe I’d be perfect!
    What did I miss?
    Re: Fanuc 21m mm to in not accurate
    Change 1001 back to it's original settings. ONLY change parameter 0000. When you change parameter 1001 you tell the controller that you have either a metric or inch ball screw. A ton of parameters are based on this setting. Parameter 0000 sets the part program to run in metric or inch. Better yet, use G20 and G21 in the program to switch between inch and metric
    Mar 2019
    94
    Got it, works, much appreciated!
    Mar 2019
    94
    Well it did change the relative position but not the machine or absolute but is traveling in inches correctly.
    Mar 2019
    94
    Sorry relative and absolute are in inches the machine is not.
  1. Accurate CAD for all your CAD/CAM/CAE Needs
    By accuratecad in forum Manufacture Company Listing
    Last Post: 10-27-2016, 12:06 PM
  2. Replies: 0
    Last Post: 03-28-2014, 08:57 PM
  3. it is not accurate yet
    By sml2010 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2013, 03:46 PM
  4. What is more accurate
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 06-07-2007, 11:49 PM
  5. How accurate?
    By bearwen in forum Commercial CNC Wood Routers
    Last Post: 02-19-2006, 03:07 PM
