This mill homes to the rear right of the bed, normally I would run Mdi from that point so all inputs would be negative coordinates.
This uses the absolute coordinates which I can’t change. As you can see if I enter 0.00 for each axis it moves to the near center of the bed, maybe used a fixture at one point?
From where should I measure my work offsets from?
Craig
