586,320 active members*
3,872 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Post processor conditional statements
    Mar 2016
    18
    Can I use conditional statements in the post processor? If so, what is the syntax? My control does not support G17,G18,G19 commands, but instead has separate commands for arc interpolation; G02/G03 for XY, G102/G103 for XZ, and G202/G203 for YZ. I'm thinking something similar to:
    *CW_ARC_MOTION*
    if "plane" == G17 then G02
    if "plane" == G18 then G102
    if "plane" == G19 then G202
    Or is there a better way to do this?
    Feb 2006
    183
    Re: Post processor conditional statements
    One way is to define the planes as 0, 10 and 20 and then use the "plane" variable for the arc motions.
    Define the planes as below.
    *PLANE_XY*
    *PLANE_XZ*
    10
    *PLANE_YZ*
    20
    Then use the "plane" variable for the arc motions as below.
    *CW_ARC_MOTION*
    G"plane"2
    *CCW_ARC_MOTION*
    G"plane"3
    /Joakim
    Mar 2016
    18
    Clever. Thanks!
    Mar 2016
    18
    Using that method, I have the following:
    *PLANE_XY*
    *PLANE_XZ*
    10
    *PLANE_YZ*
    20
    *ARC_RADIUS_CHAR*
    R
    *RAPID_MOTION*
    G00 "x" "y" "z"
    *LINEAR_MOTION*
    G01 "x" "y" "z"
    *CW_ARC_MOTION*
    G"plane"2 "x" "y" "z" "r"
    *CCW_ARC_MOTION*
    G"plane"3 "x" "y" "z" "r"
    *RAPID*
    N"lnbr" "motion";
    *END_SECTION*
    *RAPID_APPROACH*
    N"lnbr" "motion";
    *END_SECTION*
    *RAPID_RETRACT*
    N"lnbr" "motion";
    *END_SECTION*
    *APPROACH*
    N"lnbr" "motion" F"feedz";
    *END_SECTION*
    *FIRST_CUT*
    N"lnbr" "motion" F"feed";
    *END_SECTION*
    *CUT*
    N"lnbr" "motion";
    *END_SECTION*
    This outputs a G00/01/02/03 command for every movement. My control has limited memory and must drip feed so it'd be nice to keep the code as minimal as possible. I can strip out the extraneous commands in excel, but is there a better way of writing the post to do this?
  1. Replies: 1
    Last Post: 01-02-2021, 11:05 PM
  2. if statements...
    By deadlykitten in forum Okuma
    Last Post: 11-07-2015, 01:46 AM
  3. Conditional looping. Is it possible?
    By zedodia in forum Mach Software (ArtSoft software)
    Last Post: 06-15-2015, 03:08 PM
  4. Conditional and Loop Statements in Mach3
    By Monotoba in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2010, 03:12 AM
  5. If / Then Statements
    By Nanker in forum G-Code Programing
    Last Post: 10-23-2004, 06:11 AM
