586,123 active members*
3,067 visitors online*
    Aug 2006
    Angry Mori Seiki SL-204
    Anyone have one of these? The Mitsubishi motherboard has crapped out in mine. I got a new one, but need the parameters to put back in it. More specifically the maintenance parameters. According to our servise guy we have them, but in the wrong format to load into the machine WTF??????? Mitsubishi and Mori both have the parameters in the wrong format. They also can not be loaded in manually. What good is keeping a parameter file in the wrong format? I need the files labeled All1, All2, and All3. If I can not find them the machine is toast @#!?&
    Jul 2007
    Mitsubishi parameter file
    DCWorld,
    We repaired a Mori Seiki CL-153 about a year ago that lost its memory as well. We had the same problem you are talking about, I had to make the Mitsubishi techs on the phone understand that they could use their in-house programming control in their shop and hand load the parameters into it, then email me the correct files that I could load in, it took several hours in two days to get resolved, very frustrating. I do not envy you with this particular problem. Good luck.
    Brad
  1. Mori Seiki NH4000 T com
    By pieface in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-26-2023, 06:50 PM
  2. Mori-Seiki SL-3H
    By B_Bueno in forum MetalWork Discussion
    Last Post: 12-20-2011, 04:00 PM
  3. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
  4. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
