586,042 active members*
3,743 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Multi part fixture 60off with Siemens 840D controller
Results 1 to 8 of 8
    Feb 2011
    16
    I have a multi part fixture which holds 60 parts.
    This fixture goes on the machine daily to machine parts over night.
    I want to be able to put the fixture on and probe align the fixture in G54 and pick the fixture up in G54, which is the easy part.
    What I want to do is machine the part with G55, therefore I want to move to position of each part in G54 and then set G55 at center of the part with X0 Y0 and say Z25 and also the rotation that is in G54 and machine the part with a sub program
    My thinking behind this is that the fixture doesn’t have to be clocked up (In effect it could be 20deg out of square). each component is critical with rotation when on the fixture as it is already part machined.
    This can be done with a G10 in Fanuc but not sure on the Siemens controller
    Hope this makes sense
    Sep 2002
    1956
    Re: Multi part fixture 60off with Siemens 840D controller
    If I understand correctly what you are trying to do it means that you want to concatenate G54 and G55. That's not possible because both frames can't be active at the same time.
    But you can concatenate other frames. One option would be to keep G54 active and selecting your specific part by using TRANS in your NC-programme. With the values in your example:
    TRANS X0 Y0 Z25
    When you want to go to the next part you just write the new offset in a block with the same syntax.
    If you want to change your offset incrementally replace TRANS by ATRANS for example:
    ATRANS X10 Y10 Z0
    Aug 2009
    1573
    Feb 2011
    16
    So to clarify I want my main program to use G54 to go to position then set G55 to X0 Y0 Z25 then call a sub program that uses G55.
    The reason being if the job needs stopping to run another job or because of a Brocken tool you can just go to part 20 on the main program and hit go as an example.
    Does the TRANS also copy the rotation from G54 as well?
    Sep 2002
    1956
    Using TRANS does not influence G54 i.e. TRANS is effective relative to the coordinate system defined by G54.
    So zero offsets and rotations of G54 stay active.
    Concerning your question whether TRANS copies the rotation of G54:
    Both G54 and TRANS are active simultaneously. Both frames are concatenated where TRANS lies behind G54 in the chain of active frames. The exact sequence of frames is irrelevant if you use linear offsets only but it is relevant if rotations are involved.
    Perhaps you also should have a look at chapter 5 (Coordinate transformation (FRAMES)) in the following Siemens documentation:
    https://support.industry.siemens.com...dti=0&lc=en-WW
    Feb 2011
    16
    managed to get this working how i wanted
    when i moved to postion in G54 i then swapped to G55 and ran this line which read in the machine postion
    G55 would look like:
    $P_UIFR[2,X,TR]=$=AA_IM[X] ; new position x
    $P_UIFR[2,Y,TR]=$=AA_IM[Y] ; new position y
    this did exactly what i wanted it to do,
    now the only thing left to do is find the variable for the G54 Z rotation
    i'll then write that into an R then swap to G55 and input the R value saved from G54
    Sep 2002
    1956
    I don_t thin that $=AA_IM[X] will be accepted by the controller. It should read
    $AA_IM[X].
    For the rotation you may write
    $P_UIFR[2,Z,RT]= < Your R-Value >
    Feb 2011
    16
    Quote Originally Posted by CNCFr View Post
    $AA_IM[X].
    yes you were correct it was just my typo
    thanks for the rotation setting though $P_UIFR[2,Z,RT]= < Your R-Value >[/QUOTE]
  1. multi part fixture reference
    By Uman in forum Tormach Personal CNC Mill
    Last Post: 03-07-2017, 03:21 PM
  2. Backing up a Siemens 840d controller
    By byates2 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 04-13-2016, 11:10 PM
  3. Setup using a Siemens 840D controller
    By paulsand in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-16-2013, 01:50 PM
  4. Help with multi-part fixture
    By Pharkas in forum MetalWork Discussion
    Last Post: 09-12-2012, 04:07 PM
  5. Multi-part Fixture with Single Point Clamping
    By Geof in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-22-2011, 03:13 AM
