586,043 active members*
3,587 visitors online*
Results 1 to 5 of 5
    Aug 2020
    3
    will it work ?
    I have tb6600 stepper motor driver
    57A3 stepper motor (datasheet attached)
    will this power supply(specs attached) work? or I will blow it?
    Dec 2013
    5717
    Re: will it work ?
    That's a lot of power supply. But the voltage is a bit low for that drive to get any performance out of the stepper motor. But no, it won't blow anything up if correctly wired. I recommend a fuse between the power supply and the drive, maybe a 6 Amp fast blow because the drive is rated at 5 Amp
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    3
    Re: will it work ?
    yes driver is rated at 5A but many places I read that driver takes only what it needs from the power supply
    I don't know if it's true or not
    Dec 2013
    5717
    Re: will it work ?
    Yes, that is correct. It is normally good practice to add a fuse ahead of the drive to protect the drive, especially when the power supply is capable of turning that drive into a flaming puddle of goo if there were a short or something. 133 Amps is a lot of available current.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    3
    Re: will it work ?
    update
    I tried it with fuse
    its correct "driver only takes how much it wants from the power supply "
  1. Replies: 4
    Last Post: 11-20-2018, 09:37 PM
  2. Replies: 2
    Last Post: 12-23-2015, 05:52 PM
  3. Laid-off from work but made my G0704 CNC start to work
    By GLENNCAI in forum Benchtop Machines
    Last Post: 10-24-2014, 01:57 PM
  4. Trade of services Cad work + Cash for CNC work.
    By asv4k8 in forum North America RFQ's
    Last Post: 11-20-2012, 10:40 AM
  5. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
