586,077 active members*
3,711 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > MasterWood CNC Router No File Access Possible Error.
    Jan 2018
    5
    Exclamation MasterWood CNC Router No File Access Possible Error.
    We recently got a Masterwood Project 360 CNC Router. We have a problem after loading a program in Master AT software, and start program, then it stops and says ERROR 20346 NO FILE ACCESS POSSIBLE.
    Does anybody know how to fix this?
    Nov 2009
    5
    Re: MasterWood CNC Router No File Access Possible Error.
    The machine has Beckhoff CNC, probably a sub program (cycle) called from the main program created by MasterAT is missing. In the errore message You can find which is the cycle missing
  1. Masterwood 327 Problem - Error code 0.0.0090
    By Master327 in forum CNC Machining Centers
    Last Post: 08-11-2021, 08:25 AM
  2. Fanuc controller can access the files in FTP server but gives file size error
    By Semih__ in forum Controller & Computer Solutions
    Last Post: 11-19-2018, 11:51 PM
  3. Slow file access
    By Michael M in forum Centroid CNC Control Products
    Last Post: 05-22-2018, 05:14 AM
  4. M70 Mitsubishi CNC Controller Program file access through Ethernet
    By sachincool786 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2016, 03:36 PM
  5. Masterwood 327 Error codes
    By cure1 in forum CNC Machining Centers
    Last Post: 06-07-2012, 02:30 PM
