586,069 active members*
3,387 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP-U10M DNC-B
    Exclamation Okuma OSP-U10M DNC-B
    Recently we moved our MX-55VB with a OSP-10M Control across the building. Once everything was set back up, our DNC-B has stopped working. We've ordered a new cable which arrived today, and still are having issues. Getting the "DNC-B Operation 306" Alarm often. Currently the software and the parameters under the CMPS match, such as the baud-rate, stop bits, etc. But my boss insisted that our IT guy take a look and I have no idea if he changed any parameters under the bit, word, or long word sections. Any help would be appreciated.
    Apr 2009
    1262
    Re: Okuma OSP-U10M DNC-B
    Well the obvious thing is to ask your IT guy if he changed anything...;-) I would guess that he did not since he probably wouldn't even know how to get into the CMPS parameter display pages. When you say you ordered a new cable, did you order it with the custom pin outs required to make an Okuma work or was it an off the shelf cable? I would suspect cabling first since all you did was move the machine. Setting everything back up means what? Did it have it's own PC and cable that went with it or did it get connected to a more central system used throughout the building? I'd suggest getting a local PC to test out your cable doing simple download and then upload the same file. Once you prove the cable works, then concentrate on the DNC system. Do you have another Okuma with a working cable/connection that you could swap with to prove out?
    Experience is what you get just after you needed it.
  1. Okuma MX-55VB OSP-U10M
    By Arthellaus in forum Milling
    Last Post: 12-09-2020, 02:26 PM
  2. Okuma Osp U10M alarm 995
    By aventtini888 in forum Okuma
    Last Post: 01-23-2019, 01:54 PM
  3. Okuma U10m :getting program to run
    By kirby in forum Okuma
    Last Post: 01-11-2018, 02:12 PM
  4. Okuma OSP U100M / U10M
    By bajivan in forum Okuma
    Last Post: 11-07-2014, 02:20 PM
  5. Okuma osp-u10m
    By babanh in forum DNC Problems and Solutions
    Last Post: 01-18-2012, 02:29 PM
