586,058 active members*
3,435 visitors online*
    60W chineses laser cutter main switch
    Good afternoon, we are a small company in Laredo, Tx and we have a 60W chinese Laser cutter that we use for engraving in Tumblers, cutting boards, acrylic and wood. Last week after 4 years it did not turn on and what I was told by an electrician it might be the main switch. We have been looking for it but with no luck my question is do you know where I can find this switch. Another thing the electrician told us is that if it's not the switch he would need the electrical diagram and if we can't find a part the diagram is impossible. Hope you can help us.
    Thank you
    Alfredo Salazar
    Attached Thumbnails Attached Thumbnails Swicth 1 IMG_4008.jpg   Switch 2  289B1379-EA6B-420D-AAEA-BEC8D31BFCE3.jpg   Switch 3  61861068874--564B8418-0E9C-4DBB-986B-7CDB779C2833.jpg
    Jan 2008
    940
    Re: 60W chinses laser cutter main switch
    In the third pic there is a fuse in the side that the power cord plugs into.
    Mar 2020
    Yes, like fixtureman1 suggested, take a small flat head screwdriver and pry out the fuse where you plug in the power cord, assuming of course that you haven't already tried that, I learned about that just last night when my chiller quit working after about 5 minutes, I never knew it was there.
    Good luck.
    Quote Originally Posted by fixtureman1 View Post
    Sorry for the delay in answering. Yes, I did and so I been looking for a 15 amp fuse at is 2mm long and can't find it.
    - - - Updated - - -
    Apr 2005
    304
    It is 20mm long by 5mm diameter.
    Manufactured up to 16A.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Replies: 3
    Last Post: 05-20-2022, 03:27 AM
  2. Laser cutter tripping house safety switch
    By taderz80 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-21-2020, 08:22 AM
  3. VMX42 Main Electrical Breaker (Switch)
    By Burgs in forum HURCO
    Last Post: 05-18-2019, 11:33 PM
  4. China first set combination of fiber laser cutter &co2 laser cutter ,in one machine
    By laserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2017, 09:00 AM
  5. How to connect laser tube/power suply to the main board?
    By zoran0502 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2014, 10:49 PM
