586,102 active members*
2,970 visitors online*
    Aug 2020
    Cant connect to Hyundai HIT-15s!
    Hi guy,
    We are trying to send code to our recently purchased Hyundai HIT-15s cnc lathe but are having no luck. We are using Fusion 360 and have the correct post for the Hitrol-840c controller and are using the Rs-232c to usb adapter and the machine still does not receive any code when we try to post. We have the correct drivers for the connector as well. Please help.
    Thank you.
    Nov 2011
    6
    Re: Cant connect to Hyundai HIT-15s!
    Hello,
    Did you solve the problem with connecting your Hyundai to your PC I had this problem and there are a few things you need to check to make it work.
    Message me if you would like to see if what I did will help you.
    [email protected]
