586,068 active members*
3,767 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > M16 orient moving is not good
    Aug 2020
    I'm using okk's pcv-510 machining center.
    There is a problem with tool change.
    While in M16 commend, spindle can't find the location and spinning countinously. With an error message 2026 oreint moving is not good.
    This proble is not in every situation. It occurred when machine using over some hour.
    I try to do something. Already change magnetic sensor and plc plate. but still not good working.
    Is there anyone can help? I also need a pcv-510's manuals too.
    thanks.
    Mar 2019
    Re: M16 orient moving is not good
    I'm wondering if you found the solution to this, I'm experiencing a similar problem. I have an OKK PCV-55 and the spindle will not orient. Using m-code or pushing control panel button to orient the spindle, it spins slowly and slowly comes to a stop and then a "1026 spindle orient moving is not good" alarm. I've also replaced the magnetic sensor and PCB and it didn't fix it.
    Thank You!
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  3. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  4. Moving On Up, Come Get Some Good Stuff
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 12-07-2010, 08:09 PM
