586,036 active members*
4,285 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What's a good 60v stepper driver?
    May 2018
    52
    The TMC5160 chip can handle up to 60v. However, the two lower priced breakout boards that Trinamic offer for it are voltage limited to 36v, and Trinamic says that this is do to their choice of mosfets, which are only rated to 40v: https://www.trinamic.com/fileadmin/a...eet_Rev1.1.pdf
    Is it true that higher voltage will offer up faster acceleration/acceleration? What are some common drivers that accept up to 60v, and what are some motion control boards that allow for that? I ask because I'm discovering that a number of motion control boards (e.g. the Woodpecker board) will actually decrease the input voltage down to 12v before sending it off to the drivers, and, of course, this mostly defeats the purpose of supplying the board with higher voltages.
    May 2015
    686
    Re: What's a good 60v stepper driver?
    Lam Technologies DS1073 and DS1076 can handle 90 volts DC and the equivalent DS1073a and DS1076a are equivalent units that take 65 volts AC
    https://www.lamtechnologies.com/Prod...=EN&idp=DS1073 and give 90 volts to the motor.
    The advantage of the ac drivers is that you don't need to rectify an AC toroid power supply becasue you can connect the AC output from the toroid direct to the driver (which is what I do).
    Rod Webster
    www.vehiclemods.net.au
    Gecko G201X, Leadshine EM806
  1. VFD OVER VOLTAGE AT HIGHER RPMs
    By Jtcooper2008 in forum Spindles / VFD
    Last Post: 07-26-2020, 08:16 PM
  2. advice on voltage and amps to run higher RPM
    By Ncrazyballa in forum Stepper Motors / Drives
    Last Post: 07-21-2012, 12:40 AM
  3. Able to run motor with higher voltage driver?
    By Syphonics in forum CNC Machine Related Electronics
    Last Post: 04-22-2009, 02:49 AM
  4. Capacitor at higher voltage?
    By DAB_Design in forum Gecko Drives
    Last Post: 12-18-2004, 11:46 PM
  5. Replies: 1
    Last Post: 07-27-2003, 12:31 AM
