586,116 active members*
3,482 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang 2.2kw fan direction question
    Feb 2013
    81
    I have a Huanyang 2.2kw. It has a top mounted fan. It blowing air upwards drawing it out of the case but i'm wondering if its wired wrongly and is supposed to blow air down into the case and across the fins as it does in in my 3kw Huanyang.
    Which is the correct orientation?
    15362
    Re: Huanyang 2.2kw fan direction question
    Quote Originally Posted by marbles View Post
    Basic thermodynamics' it is better to draw the air up and out, but as you say they could have it either way, depending on the design, it will trip a fault if it over heats so not much to worry about
    Mactec54
  1. Replies: 15
    Last Post: 02-24-2020, 09:23 PM
  2. Another Huanyang VFD question
    By pacer in forum Phase Converters
    Last Post: 04-22-2016, 06:35 AM
  3. Replies: 3
    Last Post: 03-01-2016, 08:47 AM
  4. Huanyang 2.2 KW VFD Input Voltage Question.
    By Uni-CNC919 in forum Spindles / VFD
    Last Post: 03-08-2015, 11:48 PM
  5. huanyang; a different question!
    By Mocha in forum Phase Converters
    Last Post: 03-21-2012, 09:55 AM
