586,075 active members*
4,228 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Mar 2020
    60
    Smile Re: Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z
    hey,
    i finally finished my upgrade. Now i need to trim the surface. from 0.085 to 0.000 any tool recommented to this job.
    The material i used to do this project:
    1/2 steel plate 19x30
    18, M6 hex screws
    Quarter inch finish plywood
    M6 inserts.
    Attached Thumbnails Attached Thumbnails IMG_0669.jpg   IMG_0670.jpg   IMG_0671.jpg   IMG_0672.jpg
  2. #22
    Mar 2020
    60
    PS.
    i guess i can't use this tool, Unless i trim the shaft down to 12mm, to make fit ER20 collet #12.
    Any ideas
  3. #23
    Nov 2012
    1267
    Quote Originally Posted by akihiko View Post
    I very much doubt you could use this tool even if you manage to fit it in the collet. The spindle would not have enough torque, and the machine itself would not have enough rigidity. Something like 1/2" cutter (or smaller) would be more realistic.
  4. #24
    Surfacing that plywood is not going to result in a very good finish.
    You'd be better off adding some MDF on top and surfacing that.
    Just get a cheap bit like this.
    https://www.amazon.com/Yonico-14973-...480408&sr=8-28
  5. #25
    Mar 2020
    60
    hey,
    I'm Thinking of Upgrading my Stepper Motor's to --> Closed Loop Stepper Motor.
    I'm looking at two differen Closed Loop Stepper Motor.
    1. STEPPERONLINE 1 Axis Closed Loop Stepper Motor Kit 2.0Nm 1000CPR Nema 23 Closed Loop Stepper Motor+0-7A 24-50VDC Stepper Driver+2 Extension Cable $106.99
    OR
    2. RATTM MOTOR, Nema23 3.0Nm Closed Loop Stepper Servo Motor 88mm 5A+HSS60 Hybrid Driver CNC Kit $145.99
    Which one would will be a good choice?
    Would appreciate a good feedback.
    thanks.
  6. #26
    Mar 2020
    60
    Just fine out that (STEPPERONLINE 1 Axis Closed Loop Stepper Motor Kit 2.0Nm 1000CPR Nema 23 Closed Loop Stepper Motor+0-7A 24-50VDC Stepper Driver+2 Extension Cable)
    It only a 2.0 283.28 Torque(oz.in)
    And the next one up it a (E Series Nema 24 Closed Loop Stepper Motor 4.0 Nm(566.56oz.in) Encoder 1000CPR) Which is better. for $120.00
Page 2 of 2 12
  1. Wantai SS880 closed loop stepper drive tuning
    By danilom in forum Stepper Motors / Drives
    Last Post: 03-12-2020, 03:07 AM
  2. stepper motor tuning Need help)
    By miwaba in forum Stepper Motors / Drives
    Last Post: 06-14-2017, 03:14 AM
  3. Stepper Motor Tuning
    By bcmaint in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-09-2016, 01:48 PM
  4. help with stepper motor tuning
    By Dale gribble in forum Stepper Motors / Drives
    Last Post: 11-25-2009, 10:24 AM
  5. 3 axis stepper motor drive
    By Paul V in forum Shopmaster/Shoptask
    Last Post: 02-24-2007, 09:34 PM
