586,058 active members*
4,663 visitors online*
IndustryArena Forum > Manufacturing Processes > Safety Zone > "spindle guard" instead of an enclosure, or something else maybe?
Results 1 to 6 of 6
    Sep 2015
    43
    Hi
    I am building my first mill (40mm series extrusion frame) and I would like to skip building a huge and expensive box around it. How to protect myself from the bits breaking and flying like shrapnels of a grenade without an enclosure?
    I would like something around the bit (a polycarbonate cylinder?), obviously not perfectly to not to collide with the stock but maybe something adjustable in Z direction..with some kind of a front wall to catch up the stuff that shoots out in low angles. The cylinder could also be part of vacuum system. I will machine mostly aluminium and was considering a combined air blasting and vacuum to remove the chips and cool the bit.
    Does somebody sell something like that? Have you maube built something like that?
    Everything relevant interests, creative DIY stuff and off the shelf products.
    Thanks!
    Apr 2004
    5737
    Re: "spindle guard" instead of an enclosure, or something else maybe?
    A "spindle guard" rigid and comprehensive enough to protect you from broken bits would probably get in the way or interfere with the material being cut. What's more usual are dust boots that surround the cutting area with flaps or brushes of some sort that can bend, so they don't bang into the workpiece when the tool descends or traverses a high spot, and still allow access to change tools. These will also help deflect broken bits as they fly out, hopefully reducing the risk somewhat. But you still need to wear your safety goggles anytime you're running your machine, and not just when you're looking directly at it.
    But if you're really blasting your chips with high-pressure air, then an enclosure might be worth investing in; those sharp-edged chips will go everywhere without it. The vacuum will only pick up a certain percentage of them; you'll find another percent or two in your underwear...
    Andrew Werby
    Website
    Sep 2015
    43
    Yeah, an enclosure would be the real solution but I´m short on funds and space. The irritating part of enclosing a mill is that there are these protruding parts like the steppers in the ends of the axes that dictate the size of the box into surprisingly big and expensive.
    Goggles for sure.
    Jul 2018
    6339
    Plastic curtains? Peter
    Sep 2020
    5
    I prefer spindle guard
    Aug 2021
    me prefer spindle guard
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
