586,033 active members*
3,515 visitors online*
IndustryArena Forum > Community Club House > Education - Teachers and Students Hangout > M66 not work Philips 432 6702/700 Maho MH800E2
Results 1 to 9 of 9
    Oct 2019
    8
    hello i have a problem with my "new" Maho, i have MH600E and when i use M66 (T31 M66) on screen display "intervention" then i can open tool chuck (by button on keyboard) and putin tool, when i try do it on MH800E2, on screen is only T31 tool ready to use, but i cant put it by hand (works similiar like M67) i think there is some wrong in constant preferences, but i cant find where, can someone help me with it?
    ps.constant prefs are not the same as on my MH600E so i cant compare all of it
    Re: M66 not work Philips 432 6702/700 Maho MH800E2
    What error is showing?
    Oct 2019
    8
    there is no error, just M66 works like M67 (you see on screen your tool thats all, i made pchysical button to open tool chuck, its not sovled fine but works
    i have bigger problem, machine has wrong ways, cube 40x40x20 made 40,7x40,7x20 (Z axis is fine)
    can someone help me with constant for that cnc? i think it was repair and there is wrong parameters
    Try this constants, but first save your original via RS232 or write them on paper.
    Regarding the cube problem check backlash on X and Y .
    Oct 2019
    8
    yes i check backlash and its help... so its already work, but i think much slower then my 600E (Mhz on CPU ? can i change CPU card for faster one?)
    It is not the CPU, normally the 800 e2 is faster than the 600 e. Probably some parameter settings are bad.
    Oct 2019
    8
    G0 is faster 6000 (600e 4000) dobule tool changer, its all look much faster, but reading programm (i dont have postprocessor so i have many many many lines for make one wheel) and both has 19200 for transfer and when i put some test just load the same programm 600e ended 1000lines faster (they can take only 5500lines so its huge) but i see reading programm tookes 8000e2 more time (i can se sometimes stops on wheels, and its not problem with loading from pc but inside that awesome DX386, 600E can read lines faster than RS232 can take, 800E2 not, im trying to compare constans but they not exacly the same, so im thinikn about that math coprocessor, or maybe someone looks here and send me constants for good working M800E2 (my email. [email protected])
    You use BTR MODE for long programs? In my opinion the maximum baud rate for this old machines is 4800. I use EdgeCam for my machine with a special post processor that I modified for the vertical spindle . It outputs the code for helical interpolation in holes very short about 3 lines. It s fine for every day work. But if you want to do a 3 axis contour on a part it will output a point by point program, very long. For the horizontal spindle I use Esprit Cam with custom post processor. I found this constants for maho mh 800 e2 . Maybe it will help
    %CM
    N0 C1
    N1 C4
    N2 C512
    N4 C0
    N5 C0
    N9 C1
    N10 C3
    N11 C1
    N14 C71
    N27 C30
    N28 C0
    N29 C1
    N31 C0
    N32 C0
    N34 C0
    N37 C1
    N42 C0
    N43 C0
    N44 C0
    N51 C1
    N78 C1
    N79 C40
    N80 C0
    N81 C0
    N82 C99
    N83 C99
    N84 C0
    N85 C50
    N86 C1
    N88 C1
    N91 C0
    N93 C32
    N100 C1
    N103 C88
    N105 C1
    N108 C89
    N110 C1
    N113 C90
    N200 C1
    N202 C1
    N203 C2
    N204 C1
    N205 C60000
    N206 C30000
    N208 C20000
    N209 C10000
    N210 C1667
    N211 C50
    N212 C50
    N213 C2
    N215 C1667
    N216 C1667
    N217 C1667
    N218 C4
    N219 C40
    N220 C0
    N221 C5
    N222 C10
    N223 C200
    N224 C0
    N225 C0
    N226 C0
    N228 C3
    N229 C0
    N230 C1
    N231 C6000
    N232 C0
    N233 C801500
    N234 C0
    N235 C-500
    N236 C-802500
    N237 C0
    N238 C-800000
    N239 C0
    N240 C0
    N242 C0
    N245 C0
    N246 C0
    N250 C2
    N252 C-1
    N253 C2
    N254 C1
    N255 C60000
    N256 C30000
    N258 C20000
    N259 C10000
    N260 C1667
    N261 C50
    N262 C50
    N263 C2
    N265 C1667
    N266 C1667
    N267 C1667
    N268 C4
    N269 C40
    N270 C0
    N271 C5
    N272 C10
    N273 C200
    N274 C0
    N275 C0
    N276 C1
    N278 C3
    N279 C0
    N280 C1
    N281 C6000
    N282 C0
    N283 C501500
    N284 C0
    N285 C-500
    N286 C-502500
    N287 C0
    N288 C0
    N289 C-1000
    N290 C0
    N292 C0
    N295 C0
    N296 C0
    N300 C3
    N302 C1
    N303 C2
    N304 C1
    N305 C60000
    N306 C30000
    N308 C20000
    N309 C10000
    N310 C1667
    N311 C50
    N312 C50
    N313 C2
    N315 C1667
    N316 C1667
    N317 C1667
    N318 C4
    N319 C40
    N320 C0
    N321 C5
    N322 C10
    N323 C200
    N324 C0
    N325 C0
    N326 C0
    N328 C3
    N329 C0
    N330 C1
    N331 C6000
    N332 C0
    N333 C551500
    N334 C0
    N335 C-500
    N336 C-552500
    N337 C0
    N338 C0
    N339 C65280
    N340 C0
    N342 C0
    N345 C0
    N346 C0
    N500 C4
    N501 C1024
    N502 C-1
    N503 C2
    N505 C10
    N515 C6000
    N516 C6000
    N517 C6000
    N518 C2
    N519 C30
    N520 C0
    N521 C0
    N522 C10
    N523 C30
    N525 C30000
    N526 C30000
    N527 C30000
    N528 C2
    N529 C30
    N530 C0
    N531 C20
    N532 C10
    N533 C40
    N535 C128
    N536 C128
    N537 C128
    N538 C0
    N539 C15
    N540 C0
    N541 C0
    N542 C0
    N543 C0
    N545 C128
    N546 C128
    N547 C128
    N548 C0
    N549 C15
    N550 C0
    N551 C0
    N552 C0
    N553 C0
    N560 C2
    N565 C100
    N566 C193447
    N568 C2
    N570 C1
    N571 C746
    N572 C5000
    N573 C5000
    N574 C5000
    N580 C7925
    N581 C25
    N582 C10
    N583 C8890
    N584 C0
    N585 C0
    N586 C50
    N588 C19
    N589 C50
    N590 C10
    N591 C5
    N599 C5
    N705 C3
    N706 C3
    N707 C71
    N710 C10
    N711 C44
    N712 C10
    N714 C2
    N715 C6
    N719 C1
    N720 C83
    N723 C5000
    N724 C0
    N725 C0
    N726 C5000
    N740 C30000
    N741 C20000
    N744 C2
    N745 C150
    N746 C0
    N747 C150
    N748 C50
    N750 C0
    N751 C0
    N752 C0
    N770 C0
    N771 C0
    N772 C0
    N773 C1
    N774 C0
    N775 C1
    N776 C9600
    N785 C1
    N786 C9600
    N796 C2
    N798 C0
    N799 C1
    N800 C0
    N840 C0
    N841 C1
    N842 C0
    N843 C140000
    N844 C5000
    N845 C50000
    N846 C1000
    N847 C0
    N848 C0
    N850 C0
    N851 C0
    N860 C0
    N861 C0
    N862 C0
    N863 C0
    N864 C0
    N865 C0
    N866 C0
    N867 C0
    N868 C0
    N869 C0
    N1000 C30
    N1001 C480
    N1002 C8
    N1003 C30
    N1004 C0
    N1005 C0
    N1006 C0
    N1007 C500
    N1008 C10
    N1009 C30
    N1010 C0
    N1011 C0
    N1012 C0
    N1013 C0
    N1014 C0
    N1015 C0
    N1016 C80
    N1017 C80
    N1018 C80
    N1019 C0
    N1020 C0
    N1021 C15
    N1022 C0
    N1023 C0
    N1024 C10
    N1025 C0
    N1026 C0
    N1027 C0
    N1028 C0
    N1029 C0
    N1030 C1
    N1031 C0
    N1032 C0
    N1033 C0
    N1034 C0
    N1035 C0
    N1036 C0
    N1037 C0
    N1038 C0
    N1039 C1
    N1040 C0
    N1041 C1
    N1042 C0
    N1043 C1
    N1044 C0
    N1045 C0
    N1046 C0
    N1047 C0
    N1048 C0
    N1049 C0
    N1060 C0
    N1070 C0
    N1071 C0
    N1072 C0
    N1073 C0
    N1074 C0
    N1075 C0
    N1076 C0
    N1077 C0
    N1078 C0
    N1079 C0
    N1080 C0
    N1081 C0
    N1086 C0
    N1087 C0
    N1090 C1750
    N1091 C280
    N1092 C140
    N1093 C50
    N1094 C50
    N1100 C0
    N1101 C1
    N1102 C0
    N1103 C0
    N1104 C0
    N1105 C0
    N1106 C0
    N1107 C0
    N1108 C0
    N1109 C0
    N1110 C0
    N1111 C0
    N1112 C0
    N1113 C0
    N1114 C0
    N1115 C0
    N1116 C0
    N1117 C0
    N1118 C0
    N1119 C0
    N1120 C0
    N1121 C0
    N1122 C0
    N1123 C0
    N1124 C0
    N1125 C0
    N1126 C0
    N1127 C0
    N1128 C0
    N1129 C0
    N1130 C0
    N1131 C0
    N1132 C0
    N1133 C0
    N1134 C0
    N1135 C0
    N1136 C0
    N1137 C0
    N1138 C0
    N1139 C0
    N1140 C0
    N1141 C0
    N1142 C0
    N1143 C0
    N1144 C0
    N1145 C0
    N1146 C0
    N1147 C0
    N1148 C0
    N1149 C0
    N1250 C0
    N1251 C10
    Oct 2019
    8
    Quote Originally Posted by viorel23cnc View Post
    Yes i use BTR Mode, baudrate works faster for sure (on mh600e for 1000% sure)and i know step by step programm isnt best option, and yes mh600e can do loaded programm faster then its load from pc, but mh800e2 cant (and this is strange for me)baud rate works slower on 800e2 (i see it) but even with slower loading from PC, they cant used all lines faster than its load, so its not problem with baudrate beetwen PC and Maho, but iniside Maho
    these constans are yours? or you saw that cnc at work? or just found on web? anyway thank you ill print it and compare
