586,036 active members*
3,573 visitors online*
Results 1 to 12 of 12
    Feb 2011
    38
    Sinumerik 802c pasword help
    Hello, I just purchased a 2009 Precision Mathews 1330 cnc lathe from the original owner. This machine has the Sinumerik 802c controller. Power up, homing and jogging all work fine. When I try to go any further everything is "access denied" . Going to the password page I have entered all the factory passwords to no avail.. The original owner did not modify any of the factory passwords for this. The Siemens online tech gave me the additional password of ECHTZEIT, but this did not work either. The machine had sat unused for 5 years previously to my purchase. Can anyone help? Thanks!
    Aug 2009
    1573
    Re: Sinumerik 802c pasword help
    ...ECHTZEIT is German for real time. Try that.
    https://www.collinsdictionary.com/us...glish/echtzeit
    Feb 2011
    38
    Thanks but that didn't work either...
    May 2016
    526
    Try sunrise however it may have a keylock as well to stop any interference by operators
    Feb 2011
    38
    Thank you but sunrise did not work. Can you explain anymore about a possible "key lock" you mentioned? thanks!
    May 2016
    526
    On some older Siemens there were different coloured keys to stop operators doing stuff they were not meant to private message me your email and ill send you a pic
    Feb 2011
    38
    could you refresh my memory on how to do a PM? thanks
    Feb 2011
    38
    OK figured out the PM but error says your message box is full..... :-)
    Aug 2009
    1573
    ...must be a way to reset the password....jumper on the motherboard any where?
    in the manuals some where hopefully
    SINUMERIK 802S/802C Manuals User Guides - CNC Manual
    Feb 2011
    38
    Thanks for the link. no clue about a jumper, looks like I can set the start switch located inside the controller to #1 position and this will do a default factory boot up. The down side is that I will loose all the settings already in the machine. I don't care about programs and tool offsets but I sure don't want to loose all the tweaks the motors and ball screws got at the factory. because the machine sat for 5 years without running, part of he memory has been lost according to the manual. 50 hrs is all you get without power before you loose it. This controller has no battery backup. I am in the process of trying to do a data save to my PC before I turn that start up switch to the #1 setting. Any more thoughts are appreciated! thanks
    Quote Originally Posted by erikh206 View Post
    You can ask Siemens if there is higher level password, which could reset all the lower level passwords.
    For example, the level 2 password can reset password of Level 3, 4, 5.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Feb 2011
    38
    Thank you, Yes I talked with Siemens support and they finally gave me the word ECHTZEIT, I believe this one should be above SUNRISE, EVENING and CUSTOMER. I have no alarms, the machine will even run an existing program in the controller. My problem is I cant change a single offset or anything because I am "access denied" Im also reading that I need the "802c TOOL BOX program/CD" that might have come with the machine.... Thanks!
  1. retrofitting with sinumerik 802c
    By is_razi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-17-2020, 09:34 AM
  2. Sinumerik 802C PLC error
    By Boobo-oobo in forum SIEMENS -> GENERAL
    Last Post: 12-16-2020, 05:10 PM
  3. Sinumerik 802S/802C postprocessor
    By claudiu220405 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-17-2014, 03:13 PM
  4. SINUMERIK 802C DNC
    By sjh in forum Controller & Computer Solutions
    Last Post: 12-04-2013, 10:14 AM
  5. Sinumerik 802S/802C postprocessor
    By claudiu220405 in forum Controller & Computer Solutions
    Last Post: 05-25-2011, 07:16 AM
