586,075 active members*
4,217 visitors online*
    Mar 2020
    20
    mach3 constant velocity
    I'm struggling with shapes being overly rounded with constant velocity on, I'm trying to tweak CV "dist tolerance" and "stop cv on angle" settings but its not having any effect,
    This happens only on occasion and strangely in this instance the part comes out fine when machined with 1/4" tool but curved with half inch tool. If I uncheck CV with the half inch tool then it comes out ok but takes forever.
    By default the CV settings were dist tolerance 1 and stop cv on angle > 90... I tried dist tolerance 25 and stop cv on angle > 45 (based on things I saw online). It made no difference, I don't fully understand the meaning of these settings so I'm not too keen on playing around with them too much.
    I'm thinking is it possible that this has to do with the faster feedrate of the half inch tool, then the acceleration and deceleration would have more of an impact on the final shape?
    In the image added I drew a blue line to show the shape I'm supposed to get and if you look at the actual result you can clearly see how it actually gradually tapers down into an oval shape.
    Re: mach3 constant velocity
    Mach3's CV mode (and trajectory planner) is severely flawed. Especially when 3D cutting.
    CV mode's purpose, is to try to maintain the commanded feedrate (constant velocity). It does this pretty well.
    The problem is that accuracy goes out the window, and none of the controls that should help control accuracy work all that well.
    The best option is to increase acceleration as high as possible, if you're machine has the power to do so. Higher acceleration allows the machine to follow the path closer when directions change.
    The second best option is to slow down, which has the same affect as increasing acceleration.
    Even when you get it cutting really good, there are bugs in the planner that can result in small, random gouges in your parts.
    A friend of mine makes small, precise wood parts, and could not get Mach3 to give acceptable results. He switched to UCCNC, and got better quality parts, 30% faster.
    Mar 2020
    20
    Ah I see that's kind of unfortunate. So does the distance tolerance unit control acceleration or is that something different?
  1. Mach3 Constant Velocity vs. Exact Stop
    By 520052 in forum DIY CNC Router Table Machines
    Last Post: 02-29-2016, 03:09 PM
  2. Does anyone use constant velocity mode?
    By CptanPanic in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2012, 12:55 PM
  3. Constant Velocity settings
    By Ranscon in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2009, 01:08 AM
  4. constant velocity help
    By shnitzel in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2008, 03:10 PM
  5. constant velocity and power settings in mach3 plasma cutting
    By Knut in forum Waterjet General Topics
    Last Post: 09-28-2006, 04:19 AM
