586,069 active members*
3,363 visitors online*
    Feb 2009
    214
    belt alignment
    I have used this CNC Taig mill for 10 years. I would start having belt problems and realign and it would work.
    Now I am having problems and it looks lined up to me, but the first thing happens is the belt twists and then it goes under a load and breaks.
    Is there any info on a way to line this up besides eyeballing it?
    David L. Aery
    www.hooksolutions.com
    Feb 2009
    214
    Re: belt alignment
    I found some useful info on Google.
    David L. Aery
    Jun 2011
    68
    Re: belt alignment
    First check the motor support is square to the Headstock.
    Next I use my Starrett #13 adjustable 4" sqaure to check alignment.
    Place the body on the Headstock extrusion.
    Now use the blade to check the belt alignment..
    Stuart
    Good Luck
    Feb 2009
    214
    Re: belt alignment
    thanks! that did the trick. my pulley was too low.
    David L. Aery
  1. How to upgrade large (1500x2000mm) router from GT2 belt? Maybe 15mm HTD5 belt?
    By morten_denmark in forum DIY CNC Router Table Machines
    Last Post: 09-14-2017, 11:12 AM
  2. Easy alignment of spindle belt
    By Jeff-Birt in forum Taig Mills / Lathes
    Last Post: 11-15-2010, 03:22 AM
  3. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  4. Belt size/spec for Sieg X3 driving belt
    By rashid11 in forum X3/SX3/G0619/G0463
    Last Post: 02-10-2007, 02:01 PM
  5. Seeking Belt Sander Belt Source 6 x 48
    By Dugg in forum Uncategorised MetalWorking Machines
    Last Post: 12-24-2006, 04:48 PM
