586,104 active members*
3,276 visitors online*
Results 1 to 1 of 1
    Mar 2007
    Atrump Bed Mill Retrofit
    I'm retrofitting an Atrump bed mill, getting rid of the old Galil controller using Camsoft software and replacing it with Skyko P100 pixie controllers and Mach 3 software the machine is equiped with Baldor equipment as follows
    DC motors MTE-4090-BLBCE, Servo drives LD4-03S, and Amplifier boards LD3015-HS set to run in velocity mode. The Skyko boards are routed through 2 Parallel port breakout boards to interface this all to a Pentium 4 computer running Windows 2000
    I have ran Baldors startup procedure for tuning the Amp board and motors. I just can't seem to get the pixiecom tuning to work, the best graph I have been able to get is attached.
    Any ideas, the PID setting shown are the last numbers I tried I've been up and down the scale for a week trying to get something to work and smooth out the graph, but with no luck. And it will not repeat the same graph.
  1. Sharp Mill retrofit
    By RJ. in forum Vertical Mill, Lathe Project Log
    Last Post: 06-01-2019, 04:46 AM
  2. cnc mill retrofit
    By jimsuhr in forum CNC Machine Related Electronics
    Last Post: 09-10-2008, 05:01 PM
  3. Need advice on H.F. MILL retrofit
    By huios in forum Benchtop Machines
    Last Post: 08-24-2006, 04:31 AM
  4. ATRUMP lathe?
    By Balanceguy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2006, 07:03 PM
  5. Looking to retrofit a Mill
    By the_0utsid in forum Community Club House
    Last Post: 11-15-2005, 09:07 AM
