586,500 active members*
2,703 visitors online*
Results 1 to 6 of 6
    Question Z Axis Touch Plate Recommendations
    I'm looking for recommendations for an inexpensive touch plate for setting the Z axis on my DIY CNC router.
    In my searches I see a lot of hockey puck and plate style devices that don't seem to have any compliance or over travel capability. This can't be good.
    I see some brass button styles starting at ~25$. Most of the comments say they have to be reworked due to poor continuity.
    What would you recommend?
    Jan 2013
    228
    Re: Z Axis Touch Plate Recommendations
    I use a switch that is repeatable to 3 microns. this one
    I purchased it on eBay for around $20 it moves about 1/8" before it triggers, then has 1/4" of travel after the trigger point.
    In use, I rapid down to the switch, when it triggers I retract 1/4" then move down at 5 ipm, retract 1/4" then move down at 5 ipm again and take the average of the Z position both times. I exported the output the an excel spread sheet after doing it 100 times. I found the accuracy was repeatable within +-2 microns, and about 75% of the time it was the exact same value.
    I like this method because I have an ATC and I can set depth as part of the change cycle, and don't have to worry about additional wires etc, to complete a circuit.
    Nov 2011
    205
    Could you reveal the brand, supplier or Ebay seller of the product?
    Don
    May 2004
    210
    I don't think the one linked to is the one he bought for $20 on ebay... At least, not based on the listed price.
    Jan 2013
    228
    The one I linked to is the one I use. The seller only had one, it was a lucky purchase. When I was researching doing this, I saw other using a hall effect sensor, but the issue with them is that the amount of metal at the end of the cutter could affect depth.
    If you do a little googling you can find mechanical limit switches that are position repeatable. I believe most of them are just hall effect sensors in a nice package, where the mechanical switch trips the hall effect.
    The biggest problem I have with mine is that once in a while a chip will land on it and goof up the depth, I plan to add blow off, but need more time!
    May 2004
    210
    Quote Originally Posted by TTalma View Post
    Fantastic score. You should buy some lottery tickets...
  1. Zero touch plate holder for Z-Axis
    By Kosh in forum Avid CNC
    Last Post: 10-24-2017, 01:40 AM
  2. Z axis touch plate
    By 1601chief in forum Mach Wizards, Macros, & Addons
    Last Post: 09-19-2013, 04:43 PM
  3. Z axis touch plate
    By spalm in forum Mach Software (ArtSoft software)
    Last Post: 10-08-2011, 07:03 AM
  4. Need help with Z axis touch off plate
    By Ed Lang in forum Techno CNC
    Last Post: 04-15-2010, 03:58 PM
