586,069 active members*
3,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Help - Anyone Recognize This Drawbar Config???
    Jul 2005
    46
    Hello. I'm looking at a manual Bridgeport that's going to be for sale, but the seller was not the former operator of the machine. When going to remove the right angle attachment that is currently on it, found this. I'm only familiar with the common male hexagon drawbar. Does anyone recognize whats going on here? The inside bore is smooth and round. Not splined, keyed, female hex, etc - just smooth. And it's only about 3" deep with a flat bottom, it's not a through hole. I'm guessing it's related to some type of power drawbar that may have been removed? Or is there some type of cam-locking manual method I'm not familiar with? Thanks in advance for any help!
    Aug 2009
    1573
    Re: Help - Anyone Recognize This Drawbar Config???
    that's a pen Precise V5/V7: Pilot Pen
    ...Remove the right angle head (its clamped on to quill) than retract the Quill all the way up.....then you should be able to see the draw bar Hex to remove the mating Gear for the angle head.
    DJ
    Jul 2005
    46
    Thanks DJ, but I'm still confused... doesn't the drawbar screw into the right angle head? Isn't loosening it the last step to release it? Even though the allen screws are loose, the quill is already all the way up as far as it can go with the right angle head attached (top of the right angle head is against the bottom of the mill head casting).
    (good one on the pen, LOL)
  1. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  2. Anyone recognize this connector?
    By cnczoner in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2008, 03:34 AM
  3. SHW UF-2 & ISA 40 anybody recognize?
    By innova in forum Uncategorised MetalWorking Machines
    Last Post: 04-12-2007, 10:13 PM
  4. Can you recognize yourself?
    By ESjaavik in forum Community Club House
    Last Post: 05-29-2004, 03:32 AM
