586,076 active members*
3,932 visitors online*
Results 1 to 9 of 9
    Nov 2017
    7
    M3000 starting job then nothing
    M3000 5 x 10 , 300092308 , M24 board, Ethernet connection
    I bought this router used in 2004 and has been nearly trouble free, sometimes when I connect to DNC, I will pull up file to run, hit start and the spindle starts and then it just sits there, nothing on the keypad works, I have to power down ,restart and then it may run a job a few cycles then does it again, I have checked 5V it is set 5.5,
    When powering up it shows loading V4.71
    any suggestions?
    Jun 2010
    463
    Re: M3000 starting job then nothing
    Are you using Job Server as the program to communicate with the router?
    Nov 2017
    7
    yes,using Multicam job server,I have it on 2 different computers, doesn't make any difference. when I pull up a job keypad will show Validating job , Please stand By, then sometimes it just freezes up.
    Jun 2010
    463
    How are you connected to the router...
    PC to machine
    or
    PC to switch to machine...
    Ethernet comms
    or Serial cable...
    Jun 2010
    463
    PC to machine
    or
    Ethernet comms
    or Serial cable...
    Nov 2017
    7
    PC to switch then to machine, Ethernet cable.Thanks
    Jun 2010
    463
    And you are using a static IP?
    Nov 2017
    7
    yes,static IP , I may change Ethernet cable it is a long,maybe 50' it worked like normal on Friday,no issues . ?
    Thank you , John
    Nov 2017
    7
    So far so good, I changed the Ethernet cord yesterday and seems to have corrected the issue.
  1. Mach4 with multicam m3000, possible?
    By waynewalty in forum Mach Software (ArtSoft software)
    Last Post: 03-08-2015, 05:24 AM
  2. HF starting or pilot arc starting?
    By unns_boy in forum Hypertherm Plasma
    Last Post: 05-08-2013, 01:33 PM
  3. Replies: 2
    Last Post: 06-30-2008, 09:54 PM
