586,096 active members*
3,745 visitors online*
    Aug 2019
    An idea for a CNC.
    I have access to a rather large plasma table. I was thinking of using it to cut out a cnc from a single sheet of 1/2 hot rolled steel and use SBR20 linear rail kit from ebay. I already have a pretty nice spindle for my MPCNC that I'll be using.
    I put together a quick sketch of my idea what do y'all think? I'm worried that z movement will be roughly 23" and I'll loose 7" to the spindle mount. However this is just a quick idea I had any advice or input is welcome.
    Apr 2004
    5737
    Re: An idea for a CNC.
    Hot rolled steel isn't very flat to start with. Cutting a slab of it into pieces with a plasma cutter isn't going to help with that. But any surfaces you intend to mount rails to need to be extremely flat. Are you taking the rough assembly out for heat-treating and then having someone machine it flat? Or did you have some other plan that would make this work?
    Andrew Werby
    Website
    Aug 2019
    I didn't think of the surface finish on it, I guess I'll look into other materiel.
    Apr 2004
    5737
    The surface finish isn't the main problem, it's the basic flatness of the material. If you put a straightedge on top of a piece of it, you'll see daylight in places where the metal dips down a little. That's enough to keep your rails from working correctly.
    Andrew Werby
    Website
    Those round SBR20 are not a good choice, as they are not very rigid. Profile linear rails like THK or Hiwin are a much better choice.
  1. Retro-Fit... Good idea or bad idea?
    By sen2two in forum Milltronics
    Last Post: 01-11-2019, 03:01 PM
  2. Idea I had
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 06-18-2014, 01:55 PM
  3. new or old idea !
    By curious in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-28-2011, 03:27 AM
  4. Anyone tried this idea
    By SPEEDRE in forum T-Slot CNC building
    Last Post: 08-28-2011, 03:04 PM
  5. no idea
    By ruthless79 in forum SheetCam
    Last Post: 02-17-2009, 09:52 PM
