586,065 active members*
4,638 visitors online*
    Nov 2015
    260
    SSR Relay directly to the output?
    Hello.
    I use SSR relays. So solid state.
    Can I connect this directly to the output port?
    Or do you have to pay attention to something else
    Daniel
    Mar 2017
    1312
    Re: SSR Relay directly to the output?
    Yes, you can.
    Nov 2015
    260
    Thank you.
    I have the output board in operation. But I would like to wire more outputs with SSR
    Feb 2011
    138
    I have use it paralell, so can switch more things on the same port
    rgds
  1. 6.5w air solenoid directly to g540 without relay?
    By QuinnSjoblom in forum Gecko Drives
    Last Post: 09-16-2018, 03:51 PM
  2. Replies: 11
    Last Post: 02-13-2018, 03:08 PM
  3. Vfd HY02D223B inverter output relay.
    By Sekai in forum Spindles / VFD
    Last Post: 11-06-2016, 02:23 PM
  4. Hitachi WJ200 2.2kW Output Relay?
    By shaddr3 in forum Spindles / VFD
    Last Post: 11-17-2015, 05:07 AM
  5. shielded cable for relay output?
    By WoodSpinner in forum DIY CNC Router Table Machines
    Last Post: 12-17-2012, 02:41 AM
