I need to mill some parallel open ended slots(cooling fins) on an aluminum plate and I'm wondering which machining method in PartMaster Level 3 would be the best to use for this type of job? I have already done it with the slot option in the Level 3 CAM program which allows for multiple depth passes but it seems like this could be done in a much easier manner. I had done it also with the cad program but was having a problem with the Z axis not raising to the clear plane between the rows of slots and it would have done more of a contour cut around each fin, and the ends of the fins would get milled off short in length this way. Thanks in advance for any help I can get for this.
Wes
