586,117 active members*
3,343 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How to adjust spindle height for non-cylindrical spindle?
Results 1 to 17 of 17
    Oct 2017
    22
    Trying to upgrade this 3040 router with a higher torque BLDC spindle for cutting steel. Besides having a higher 1.3 Nm torque vs 0.3 Nm for the stock spindle, more importantly, the full torque is available at 0 speed unlike induction motors. I made a plate with a bunch of screw holes to allow height adjustment, but even so, it's now a lot harder to adjust the height because I have to (un)screw 4 bolts, instead of just (un)tightening 2 bolts and sliding a cylindrical spindle in its collar. Also, it will cause the aluminum threads to wear out quicker.
    What can I do? I was thinking something like a plate that slides on rails. Or would it be better to adjust the gantry height https://www.cnczone.com/forums/comme...ry-height.html or just raise the work?
    Feb 2005
    829
    Re: How to adjust spindle height for non-cylindrical spindle?
    I am not sure what the issue is, I never adjust the height of my spindle on my cnc router, that is what the z-axis is for. Could you explain why you are wanting to adjust the height?
    Oct 2017
    22
    I need to adjust it because the Z travel is only 80mm. The Z clearance from the T slots to the bottom of the Z axis is 125mm, so I can only use a portion of it. Some times I want the spindle to reach all the way to the T slots but this would be used rarely like for wood relief carvings since that will make the Z easy to flex. For cutting metal, I will have to raise the work.
    Apr 2004
    5737
    You could mount a dovetail to the back of the spindle that slides into a dovetail mount on the Z axis that locks when it's in the right position.
    Andrew Werby
    Website
    Apr 2003
    540
    I just don't think that machine has anywhere near the required build to attempt to cut steel. I wish you all the luck in the world if you make it work, please share your progress and post some photos of your results. Wood and maybe aluminum but you need a mill for steel
    Aug 2009
    1573
    ...just use a Sub plate riser
    15362
    Quote Originally Posted by machinehop5 View Post
    He is already using one
    Mactec54
    Oct 2017
    22
    Very clever, but I don't think I'll be able to cut a deep enough dovetail channel without severe runout, unless I go very slowly. How would the locking/clamping work? I was thinking you would add 1 or more extra slots parallel to the dovetails. A screw would slide in that slot that could be tightened to clamp the 2 plates.
    This was the design I was thinking before dovetailing. I would use wing nuts to easily tighten. Also, it won't wear out the aluminum threads.
    You mean like this? Is the height adjustable? I don't want to get it for several heights.
    Oct 2017
    22
    Wait, I can get most of the benefits of dovetailing with just 2 rectangular rails. Much easier to cut ! I'm going to do that. Thanks for the dovetailing suggestion. I guess that's the ideal solution
    15362
    Quote Originally Posted by spacesaver View Post
    Yes that is the way to do it, your motor plate would have the male dovetail on it and just a rail each side one fixed the other to clamp this does not have to be a dovetail, it can be just be a step which is easier to make in your case like sketch
    Mactec54
    Aug 2009
    1573
    Quote Originally Posted by coherent View Post
    x2 coherent ..good advice
    15362
    You can cut steel with a dremel, and very well, anything can cut steel, it's just how well and how efficient, most routers like this can cut steel but very poorly due to lack of rigidity and clearance in the slide bearing, backlash and a spindle not suitable to cut steel, correct those things and you can cut steel without any problems
    On large fab work all steel, I use a Bosch hand trim router to cut corner radius and chamfer the edges, so anything is posable if you have an imagination and a want and need
    Mactec54
    Oct 2017
    22
    I made the sliding rail. Much easier to adjust now. I haven't done any test cut yet.
    I'm very aware and did succeed in cutting steel https://www.cnczone.com/forums/chine...el-router.html. You just have to go very slowly and cut near the XY corners where the rigidity is strongest. The biggest weakness is the twist about the x axis due to the 2 unsupported X rails. Replacing them with supported rails would be the next improvement. The spindle getting stuck was the biggest problem and snapped lots of end mills.
    15362
    The wing nuts are not going to do a very good job, you need a plate washer to cover the slot, stud to stud, at least 5mm or 6mm thick, then a regular washer and Nut, you need a solid mounting what you have only has 4 small contact points for clamping it, which will be able to flex when cutting
    Mactec54
    Oct 2009
    733
    And your tramming might be off a bit every time you adjust the plate.
    Oct 2017
    22
    That makes sense, but I don't recall in simplified physics, friction depending on the area. If the total clamping force is the same, then so should friction. Unless the ground is mud. This isn't a car stuck in mud is it? I tried finding square washers on McMaster, but almost all the sizes are way too big and not rectangular. I guess I'll have to make my own.
    True, but that should only matter if you're cutting a very deep pocket right? I don't think I will do that.
    15362
    If you think this has anything to do with physics or friction you are mistaken, you don't want a square washer, just a piece of flat bar with 2 holes in it would be the correct way to do it
    And yes traming is important if you want to mill a flat surface, not for how deep you go it's more about the surface flatness, pockets will be correct if you have it right for milling a flat surface
    Mactec54
  1. faster spindle... Do I need to adjust feeds??
    By Us ill in forum Chinese Machines
    Last Post: 07-31-2014, 05:46 AM
  2. Replies: 2
    Last Post: 07-24-2013, 07:31 AM
  3. How to adjust spindle speed of a dc motor?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 01-25-2011, 07:44 AM
  4. Rong Fu 31 spindle adjust
    By grinderdust in forum Benchtop Machines
    Last Post: 11-23-2006, 08:13 PM
  5. Spindle Orientation Position Adjust
    By pinguS in forum Fanuc
    Last Post: 11-16-2006, 05:02 PM
