586,069 active members*
3,410 visitors online*
Results 1 to 15 of 15
    May 2020
    15
    Shuttle Jog Step button cover
    Pretty self-explanatory. Cover that "step" key with a 3d printed cover. See https://www.thingiverse.com/thing:4584044 for free download. No PathPilot script editing, etc.
    Files include 3 different covers. "Cut cover" has a notch to allow a discrete finger press of the step button if you'd like. Tall is a bit too tall but may add safety for heavy hands.
    This fit's very tightly, scale up if you'd like a looser fit. Notch is for shuttle power cord. Printing tips on thingiverse site.
    Feedback appreciated.
    Sam
    Nov 2012
    591
    Re: Shuttle Jog Step button cover
    You ... have a mill. Why would you 3D print such a shape? :-D
    Jun 2014
    1780
    I disabled mine in the PP software, there wa a post recently as to how to do it.
    mike sr
    May 2020
    15
    Hi Pops, I too read that post and others about disabling step button in software and it's a great option. I didn't want to disable mine, as I do use it from time to time.
    I also didn't know if software change would persist with each PP upgrade. Maybe you know that answer?
    Jun 2014
    1780
    Quote Originally Posted by samstu View Post
    I would think it will get overwritten with each new update. This is one disadvantage of updating PP. I do like your option as it wont change with updates, good idea!
    mike sr
    Nov 2007
    2151
    Kind of clever!
    gives me the idea to make base with some NASA type bumper guards on each side. that would allow use but still keep floating fingers off it.
    Jun 2006
    3063
    Quote Originally Posted by jwatte View Post
    3D-printing this is the best tool for the job, to my mind though it's not a huge deal either way. A 3D printer can crank this out with almost no intervention on your part. Using the mill means CAM, workholding setup, tool offset entry, tool changes, clean up, etc. as opposed to loading filament, slicing the file, loading it into the printer and hitting "Start". For my printer and setup that takes a couple minutes, much less if I don't need to change the filament. Setup in the mill isn't much longer but the CAM can really bog me down.
    Different strokes for different folks, though.
    Aug 2020
    106
    This is where I tried to download it and the link showed nothing (Guns from Hobby Machinist) Seems to be working now. This cover will come i handy as I am a CNC and Tormach newb. Thanks man!
    May 2020
    15
    Tigster / GoN
    Thingiverse had a crash a while back.
    Hope you enjoy and find useful.
    Jun 2014
    1780
    Another button that could use some sort of protection is the computer on/off switch, I hit that one again today by accident.............
    I am considering using the spindle key lock out switch as I never use that one......
    mike sr
    Apr 2012
    161
    Quote Originally Posted by popspipes View Post
    I put some red tape on my computer on/off switch. It's not a big piece that holds the switch in the on position, it's just a small strip to highlight the switch.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Jun 2014
    1780
    I think if I used the key switch it would make it non standard.
    I am thinking another switch placed away from the operator switch cluster to where it wouldnt be touched as easily.
    In my age bracket I need things kind of bulletproof ha!
    mike sr
    Dec 2008
    740
    Something like this comes to mind:
    Attachment 449762
    I think the they normally turn the switch off when the red cover is pushed down - not what you want - but something red and ominous...
    Step
    Apr 2013
    1788
    Something like https://www.amazon.ca/Switch-Guards-.../dp/B082K9WTYD might be even better since you could use the existing switch. Making your own guard to a similar design from HDPE or other plastic would be pretty easy.
    Jun 2014
    1780
    Thanks for the suggestions Guys!
    Those would work, I think if the switch was away from the regular switches it would be fine or maybe a selector type, anything different that what is there, its too close to the coolant switch to my liking.
    mike sr
  1. Replies: 0
    Last Post: 08-15-2020, 12:02 AM
  2. Jog Shuttle
    By 4stroke in forum Tormach PathPilot™
    Last Post: 01-15-2019, 08:11 PM
  3. External Single Step Button Function?
    By slimneill in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-04-2015, 09:18 PM
  4. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  5. Contour shuttle - press a button & 'Z' goes to preset coordinate?
    By HankMcSpank in forum Mach Software (ArtSoft software)
    Last Post: 09-22-2009, 02:11 PM
